Anyone install these Raptor Lights?
av8tor
Rhode Island
2024 Tacoma Off Road
I just installed the same set of grill lights on my 2024 Off Road. Is there any other fuse that I could tap into to eliminate the lights from randomly turning on?
The Dude
Richard
Calgary, Canada
I installed something similar from Amazon. I just discovered today that for some reason the raptor lights just come on all by themselves. I used the mini fuse tap and put it in where the instructions noted which would require the ignition to be on. The only reason I noticed it was I was at worked and parked outside my office. I was looking out the window and noticed they were on. The truck was off, didn't have the app open and didn't have the keys on me. It's done it two days in a row. They stay on for a random amount of time, less than 15 minutes from what I can see, then shut off.
It’s because you most likely tapped the IGN fuse. The truck, usually every 4 hours, powers the fuel pump through that fuse for emissions regulations, to eliminate pollutants from escaping the gas tank.
To eliminate the problem, you’ll have to find a fuse of significant power (ie. 10A or more), and is only on with IGN. Maybe infotainment fuse?
Joe650
Joe
Wasilla, Alaska
Thanks, much appreciated. I figured it was something along those lines. They're never on that long so I don't think it will be a huge drain on the battery.
