Dash Cam Solutions for 2024 Tacoma
ShadowShot70
Jon
Connecticut
2024 Tacoma Sport
Hello all. New guy here. Just picked up the truck today. A 24 Tacoma Sport with the Sport Premium package. For day 1, I am loving it!
I have a Blackvue DR970X 2 camera dash cam that I installed earlier this year in the car I traded in. I pulled the units but left the wiring (neatly hidden I might add)
Anyway, after lurking here a few weeks while I was waiting for my truck, I went and ordered a Donger PRO Parking Mode adapter which allegedly will arrive Friday.
My questions are many, but the biggest one is that in the examples posted earlier in this thread, the dash cams seem to connect to USB ports, which is not the case with the Blackview. It has a phono-plug type power connection.
So what are my options if anyone has done this before with a Blackview. I saw in an earlier post here that someone has done it, but the details are not detailed enough for me aging brain.
Can someone tell me if I have what I need, or what else I need to get to make this work? I have grown used to having a DashCam, and these days it's a very good idea to protect yourself from the many unlicensed and uninsured drivers out there.
Thanks! And I am looking forward to jumping into the threads on this forum
PeceKeepr
Brad
Louisville , Ky
2024 Hybrind Tacoma TRD Sport
Just got my Hybrid TRD sport a few weeks ago. And got the VIOFO A229 pro 2 channel. I bought and installed the Dongar pro but it wont allow for parking mode. Bummer. So now I’m looking to hardwire the dash cam but there’s not a lot of room which you guys know. (I read the whole forum.) Is it safe to just take the harness through the firewall and tap into the fuse box on the drivers side under the hood? Is there a better option. I literally just got my windows tinted and I didn’t use the electrostatic film so if I replace the cameras I’ll be replacing at least one window tint. Thoughts and ideas are needed. If I use the one in the engine compartment do I dril a small enough hole to allow my wires to come through where the fuse cover meets the fuse box ? Is that safe? Also can I just add a secondary fuse box is that a thing? Thanks
ShadowShot70
Jon
Connecticut
2024 Tacoma Sport
Anyone with a Dongar Pro know how to change the voltage output of the little unit? I set mine up and cut one of the USB cables included because I will have to splice it into the Blackvue cable because of the connector mismatch, then tested the Dongar Output voltage I put a meter on the red/black and the output was 5v. I need it to be 12v for the Blackvue.
I have searched the Dongar website and web for info on setting the output voltage to 12v but I cannot find any information whatsoever.
ShadowShot70
Jon
Connecticut
2024 Tacoma Sport
Talkin' to myself here, but for future reference for others:
The Dongar Pro USB-C output senses what voltage is needed and provides it. There is no user setting to change.
For those interested in connecting a Blackvue to the thing, there now is a cable available from BlackboxMyCar that goes from USB-C to the Blackvue power plug. In order to use it I had to cut it and splice it back together to get a very short cable. There are 3 wires in the cable and it's very easy to splice them using solder and shrink tubing.
Works great! The Dongar Pro is a great little unit
goin2drt
KY
I bought the Viofo wire kit. I used the add-a-fuse and ran the cable down over to the passenger footwell fuse box. Works great. Parking mode works and the big plastic footwell covers the fuse box just fine without needing to smaller black fuse cover.
M.b.1
Matt
Vancouver, WA
2024 TRD OR
I ran into the same issue. Same camera, same-ish truck. (24 trd or) I have the hardwire kit that I'll use instead. Can you tell me which sets of fuses you tapped for remote and continuous power?
*Also, I've read add a fuse won't allow the cover to snap back on. How did you get around this?
goin2drt
KY
Here you go. The little black cover can’t go on but the big black plastic cover still does and no way to hit the fuse box with your feet with it on. It all works great.
2024 Tacoma Dash Cam Solutions for 2024 Tacoma IMG_0516
2024 Tacoma Dash Cam Solutions for 2024 Tacoma IMG_0515
PeceKeepr
Brad
Louisville , Ky
An update on what I ended up doing. I have a hybrid sport. And I installed an auxbeam on the passengers side fuse box tapping into the 12volt feed there and the body ground beside the fuse box. Inside the fuse box is only one good aux power to tap into which is needed for the Auxbeam. I then ran my dash cam wires using an inline 5amp breaker to the Auxbeam 12 volt and the ground to the Auxbeam ground post and then I tapped into the auxiliary power cable that ties into the Auxbeam. I did have to go through the firewall. I’m very pleased with the install. This is the 3rd way I’ve had it installed and I gotta say for me this is the best. I don’t have any pictures of the install but here’s a few of the Auxbeam and you can figure out how I tied in the rest with the pictures if anyone is curious just send me a message
2024 Tacoma Dash Cam Solutions for 2024 Tacoma IMG_6164
Gabagool984
Anthony
Florida
2025 Tacoma TRD Sport
FYI, here are the official steps on accessing the 5-pin rooftop 'option' connector.. it is a tool-less process but it would be wise to use a flat & wide pry tool, if your fingers are too fat.
Alternatively, you can access the 10-pin mirror connector (tutorial coming soon) which we also have a product for. The 5-pin connector is present in all 2024+ Tacomas and was placed to help upsell you on the OEM Toyota dashcam. The 10-pin is absent in the models without autodimming mirrors (i.e. SR5 without premium package). We have a slight preference for using the 10-pin connector since our current 10-pin dashcam adapter is designed to be windshield mountable whereas the 5-pin version is not. Our new parking mode adapter is modular and will include both 5-pin and 10-pin harnesses in one package.
Any idea when the 5pin adapter is restocking? Been waiting for a while now.
