- Joined
- Oct 1, 2025
- Threads
- 2
- Messages
- 7
- Reaction score
- 2
- Location
- O'Fallon MO
- Vehicle(s)
- 2021 Bronco
If you’re looking to upgrade your Tacoma’s stance and performance without spending King-level money, Eibach’s PRO-TRUCK-LIFT systems are hands down one of the best bang-for-buck suspension upgrades on the market right now!
Eibach has been in the suspension game for decades. From racing to OEM development, and their Stage 2 and Stage 2R kits bring that race-proven quality to the 4G Tacoma platform. Both are designed, built, and tested in the USA and backed by a limited lifetime warranty.
Why the Eibach Lift Kit is the Best Value for the Tacoma
Unlike some budget “lift kits” that just space out your stock suspension, Eibach’s kits completely replace your factory shocks and springs with fully tuned coilovers and matching rear shocks. Here’s why they stand out:
- True Performance Lift: Up to +2.5" front lift and +1.5" rear with matched spring rates for improved handling on and off-road.
- Proven Durability: Eibach designs and tests every system to work with OEM components, so no stressing ball joints or upper arms.
- Ride Quality: Their variable force valving and ERO race springs deliver a ride that’s firmer and more controlled off-road, but still smooth on pavement.
- Easy Installation: Direct bolt-on fitment, designed to integrate seamlessly with your factory components.
- Made in the USA: Precision-built and dyno-tested, ensuring consistency and reliability.
In short, it’s a suspension you can install once and forget about, with real performance gains instead of cosmetic lift blocks or cheap spacers.
Stage 2 vs. Stage 2R — What’s the Difference?
Eibach offers two levels for the new Tacoma depending on how (and where) you drive.
Stage 2 – Balanced Daily Driver & Weekend Warrior
If you daily your Tacoma but still hit trails or gravel roads on weekends, this setup is perfect.
- Front: Adjustable coilovers with threaded perches (up to +2.5”)
- Rear: Matching Pro-Truck rear shocks (+1.5” lift capable)
- Springs: Eibach ERO Off-Road Race Springs
- Performance: Excellent balance of comfort and control; improved cornering, less nose dive, and better stability off-road
Stage 2R – Trail-Ready, Built for Abuse
For those who push their Tacoma harder, the Stage 2R is a step up in performance and cooling.
- Front: Same adjustable coilovers for precision ride height control
- Rear: External reservoir shocks for improved heat dissipation and longer travel
- Construction: Anodized 6061-T6 billet aluminum mounts, 46mm pistons, nitrogen-charged monotube design
- Performance: Better shock fade resistance and control over rough terrain — perfect for desert running, overlanding, or aggressive trail use
Final Thoughts
Both setups are built to transform the way your Tacoma rides and performs.
- Stage 2 = smooth, capable, and confident — ideal for most owners.
- Stage 2R = all out control, designed for enthusiasts who demand the best.
Either way, you’re getting one of the most well engineered and cost effective suspension systems available for the 4G Tacoma. All backed by Eibach’s legendary reliability and support!
Eibach 24+ Toyota Tacoma Stage 2 Pro Truck Lift Kit
Eibach 24+ Toyota Tacoma Pro-Truck Lift Stage 2R
