Front bumper cover
Jeff11
Jeff
Pittsburgh
The front bumper cover large painted piece that has the left and right-most parking sensors I. My truck got damaged. I will probably just buy it and have it painted and install it myself because the part itself isn't very expensive. My question is, do they come with the holes for the sensors already there? And does anyone know how the sensors mount from the inside? Thanks for any help you can provide!
Richardb106
Richard
Yuma, Az
Not 100%sure about the front but the ones in the rear are stuck on using double sided tape.
Jeff11
Jeff
Pittsburgh
Thank you! Do you know if the part comes with the holes pre drilled?
Richardb106
Richard
Yuma, Az
Not sure about the front, but when I had my rear bumper replaced the holes were predrilled
Idaho-Taco
Jevon
Boise Idaho
2017 Z06, 2018 2500 Ram, 2006 Jeep TJ
I have
I just took one off my new (30 miles) TRD off road as I wanted one that matched the PRO and TH. They are a bit of a pain but not that complicated to swap out. I show photos and discuss a little on my build thread.
Yes they come with holes for sensors (at least mine did). The existing sensor’s mount in brackets held on with double sided tape. I removed the bracket and carefully removed the stickers, replacing it with thin 3M tape I bought.
Let me know if you have any other questions. It’s a bit of a process but very doable.
Jeff11
Jeff
Pittsburgh
Fantastic information thank you!
