Truck cover / method to protect against hail
JohnSadler
Moore, OK
Toyota Tacoma TRD Off Road iForceMax Premium
I just put a deposit down for a 2026 Tacoma TRD-Off-road! I’m looking for your best solutions for a truck cover to help protect against hail. I park outside so I’m looking to prevent damage.
MJB4450
2025 SR5
Do a search for hail proof truck covers. There are several out there. Probably better than nothing. When I had to park my Dodge Challenger R/T at work during what we laughably call the "monsoon" here in Southern AZ, I bought a roll of dense rubber foam and cut pieces for the hood, roof and trunk and put a car cover over that. Challenger sheet metal is paper thin and even the smallest hail would dent it. Should be a lot easier with a truck since it's slightly thicker sheet metal and all you really need to protect is the hood and roof. So one of those supposedly hail proof covers with a couple strategically placed 1/4" foam rubber sheets should do the trick. If all else fails, do some research of review sites and find yourself a really good PDR tech.
Meggyy
Megan
Chicago, IL
2020 Toyota Tacoma
Mixing thick foam under a hail-proof cover worked well for me. Also, consider trying this Charger cover as an extra layer; though made for Chargers, it’s top quality, offers a lifetime warranty, and I found it surprisingly durable. Keeping the foam padding manageable helps with fit. Plus, if you need dent repair later, don’t worry—good PDR techs can do wonders.
JohnSadler
JohnSadler
Moore, OK
I’ve been in a similar situation and used a thick layer of quilt batting under my truck cover. It cushioned the blows and minimized damage during a hailstorm.
So far my SealSkin premium cover on top of two large harbor freight moving blankets on the hood and roof has worked well.
