G4 TRD Pro and OR: Augmenting rear suspension for towing
Josh256
Toronto, ON
2025 Tacoma TRD Pro
Hey folks.. Any recommendations on reducing sag with OR or in my case TRD Pro rear suspension? Looking at the following air spring but curious what all my options are [without replacing the stock springs/shocks]. I'm not opposed to compromised off-road performance as I don't do much off-roading and would likely reverse any modification if necessary on the rare occasion I do.. (The car gets occasional track pads and wheels/tires swaps respectively)
https://www.stage3motorsports.com/t...mbren-rear-suspension-enhancement-system.html
32spoke
Jason
Petaluma,CA
Another option, they all have trade offs, is an air lift suspension kit- the bad news is that air will always be needed to fill these even when not being utilized… just a little air, so the bags don’t get ruined. But the benefit of the air bags, is that they increase spring rate of your coil springs, level your ride height. Your rear shocks still do all the dampening, but it is like having stiffer coil springs, but when unloaded, simply lower the air pressure in the bags to return to the stock coil spring setup. If a bed or tongue weight load is constant, like with a camper setup, proper coil spring upgrades would be a good consideration.
https://www.airliftcompany.com/shop/57386
Vidman
Rick
Mass
Air bags just like 32spoke said.. I’ve had them in most of my trucks and work great
32spoke
Jason
Petaluma,CA
The airlift # 57386 is listed on the airlift website for the 4th gen Tacoma with rear coil springs… airlift may have a leaf spring option coming soon. An email or phone call to airlift may clarify what can and cannot work with each spring option-coil or leaf
Bigt
Az
24 sr5
yeah, 092535 replaces the rear springs with the airbags. The generic( PN: 60924 ) kit adds the helper bag inside the coil.
