Give Your Tools A Place to Stay with Side Bed MOLLE Panel | xipoqix
xipoqix_official
Jackie
China
The scattered tools in the car always cause headaches: they keep sliding around, making noise and even scratching the interior walls. If you have also been bothered by this, we have a new product to share with you: The Side Bed MOLLE Panel.
The 5FT Side Bed MOLLE Panel is compatible with 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017 2018 2019 2020 2021 2022 2023 Tacoma. Note: Not compatible with Tacoma TRD models.
It can fix commonly used tools to the panel, improving space utilization. You can easily reach them without having to crawl into the trunk. It can reduce the movement of items in the vehicle, reduce collision noise, and also reduce wear on the surface of the items.
Made of carbon steel, it has excellent impact resistance and deformation resistance. The surface is powder-coated, which is not prone to rust and erosion. No drilling is required; it can be installed by using the original vehicle's holes.
Get yours here: https://www.amazon.com/dp/B0HDNPLXKC
braaadyyota
Brady
Minnesota
linktr.ee
This does not list it as working with 2024+ Tacomas... Does this work with a tonneau cover, meaning does it sit slightly behind the T rail so the brackets clear? And will there be a version that does not cover the 12v outlet box?
xipoqix_official
xipoqix_official
Jackie
China
Hi, this panel only fits 2005–2023 Tacoma and does not work with 2024+ models. It is installed beneath the rail. It can be used with a tonneau cover provided that the mounting points for the panel are not occupied by the tonneau hardware. We’ll forward your requests to our R&D team.
braaadyyota
Brady
Minnesota
linktr.ee
This is a forum for 2024+ Tacomas
