Gurvy522
Gurvy522
Chicago, IL
oh good! I wanted to be sure nobody was profiteering your bracket! I bought one from you last month but my kids found it and have lost it, so I might become an ebay customer too!
Its a great deal for anyone else. Before I saw this listed today I re-ordered "cam-bracket-final-v2-ABS.step " from an online shop for pretty much the same price... but it was SLS nylon 12, do you think that is a good enough material? Thank you!
Technically people can profit off of it if they want to. I honestly don't care, lol. It's free here for those that want to print it, that's all that matters.
Yeah, nylon is great, pretty much any high-temp material will do fine, such as nylon, ABS, PETG. Even PC would work.
hemlockz
‘24 TRD Offroad 6MT
Do you remember what size of screw you used to attach the brackets to the grille's plastic holes? I don't want to get too big and crack the plastic but don't want to go too small so they don't bite deep enough, thanks!
Gurvy522
Gurvy522
Chicago, IL
Pretty sure they're standard coarse-threaded M5 screws.
I definitely remember it being a bit tight. On a brand new grill those are fresh holes so the threads are gonna cut in a bit.
demelob
Brandon
Ontario, Canada
2024 Tacoma TRD Sport+
@Gurvy522 Two questions for you, if you don't mind. Are you willing to sell and ship your brackets? I'm in Canada. Also, did your model come with a camera? I'm looking at a way to plug that hole with something cosmetically pleasing, since my model does not come with the front facing camera.
Gurvy522
Gurvy522
Chicago, IL
I made a small 3D printed plug for someone else that also didn't have a front facing camera. I could dig it up and share the file here. It just press fits in to cover the hole.
As far as the brackets, I only made two sets to meet the order minimum for powder coating. My recommendation that I've given others on this forum is to use the design and have them manufactured locally or by SCS.
demelob
Brandon
Ontario, Canada
If you could dig it up, it would be much appreciated!
demelob
Brandon
Ontario, Canada
Hey @Gurvy522. Any luck digging up the file? Much appreciated.
TygerTaco
Ty
Managed to get the final revision of the camera bracket done and printed in ABS. Came out great and seems to be a perfect fit.
Thank you so much for this! I printed and installed it this weekend on a Trailhunter grill swap, and it worked perfect after I got my print settings right ;).
taco-greg
Gregory
texas
2025 tacoma offrroad
Was tempted to go this route as well, but scooped the Heretic bar up for only $240, and the grill for sub $300, shipped.
For simple brackets, sendcutsend is a godsend. Got em black zinc'd as well for only $10 a pop total. $40 min though so I picked up an extra set, probably will sell those extra brackets here for what I paid if anyone is interested.
As far as the camera bracket, I'm fairly certain that it's just a slight change in the angle, everything else is identical. Their 3D printed version looks pretty much the same as the OE one, albeit with that diff angle. Once I pull the grill off I'll just measure out the OE bracket and print a new one for the Heritage grill. Happy to share the file here once it's done for everyone for those that want to DIY it.
Where did you manage the get the heretic light bar for$240? If you don’t mind me asking
JNAT112155
2025 Tacoma
Looking to DIY grille lights above my fog lights. The only brand I’ve found that makes something worthwhile is Heretic, but I don’t think they sell the mounting brackets separately. Does anyone know of any DIY, 3D printed options or companies that sell individual brackets for 6" light bars?
2024 Tacoma Heretic 20" LED Light Bar install on TRD Pro Grill 1768505077457-pc
Here is the mounting instructions from the website.
2024 Tacoma Heretic 20" LED Light Bar install on TRD Pro Grill 1768505249828-ai
ramcoma
united states
2025 Tacoma TRD OR HYBRID
Ended up scooping a TRD Pro Grill for a bargain and was working on getting a bracket designed to mount my lightbar.
I think the Rave guys also were working on a bracket for the Heretic to the grill but I was impatient, lol. Few tries with the good ole calipers and she's dialed in.
Seems like a great fit. Off to sendcutsend to get these lasered in some mild steel. Hope to have it mounted on the truck in a week or two. For anyone interested, not sure what other options are really out there, but the Heretic literally is a perfect fit since the brackets mount from the rear rather than sides.
I am trying to buy this light bar for my TRD pro grille, Was the wire plug that comes stalled on the light bar long enough to pass through the grill shutter into the engine bay? I know they give a wire harness, but i want to make sure i can unplug it in case i have to remove the bumper at any point.
