Lexland Seat Covers - Black Camo
tacomasport1121
Robert
2024 Tacoma Sport
They completely change the truck for those with cloth seats. Easy to install, clean, and look great after 4 month of daily use!
2024 Tacoma Lexland Seat Covers - Black Camo IMG_4305
SanantonTaco
Nate
I purchased the red set (had a snag, well a looong, well a fight snag with the double sided tape), and they are if great quality. Loving your black selection, those look also clean as factory. One of the best quality I've seen those far for the price point.
Did you remove the seat or installed with them in the truck?
tacomasport1121
Robert
2024 Tacoma Sport
Left the seats in. Jacked them all the way up. Was not too bad to install. Would be easier with seat out but I’m not sure if it’s worth the hassle and risk messing with the airbag connections. If you take the seats out I read you should disconnect the negative battery terminal for 15 min before removing due to air bag connections still holding charge. Again, 100% doable with seats in.
SanantonTaco
Nate
Left the seats in. Jacked them all the way up. Was not too bad to install. Would be easier with seat out but I’m not sure if it’s worth the hassle and risk messing with the Sienas connections. If you take the seats out I read you should disconnect the negative battery terminal for 15 min before removing due to air bag connections still holding charge. Again, 100% doable with seats in.
I did remove them, (no waiting) due to a consecutive amp install under the seat and Starlink Mini/mobile custom router wiring installation. I did disconnect the battery as I usually do when working on anything electric. Removing them made the installation super easy.
