Maybe a little bit confused... But Is anyone know where is in the background of Tow Haul mode?
popkartiphone
Jack
24 Tacoma Limited
Hello! Is anyone know where is the exact background mountains when enter the tow haul mode in 24 Tacoma on dashboard? It looks like beautiful.
2024 Tacoma Maybe a little bit confused... But Is anyone know where is in the background of Tow Haul mode? IMG_8816
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR
looks weird, and maybe a photoshopped element. if you look closely, the "same peak" appears twice:
2024 Tacoma Maybe a little bit confused... But Is anyone know where is in the background of Tow Haul mode? 1757653886486-8d
I zoomed in, and it's definitely the same peak, but at differing contrast values, so maybe they had two pics of the same range, and just used one angle for each left and right...?
You can also see another element referenced both times, so yeah, def two of the "same range" just cut and spliced up:
2024 Tacoma Maybe a little bit confused... But Is anyone know where is in the background of Tow Haul mode? 1757654026828-na
I worked in photoshop type stuff for years, so look for these kinds of things, I can't turn it off in my brain. Seeing two of the exact same egg in "different" plates in the Denny's menu etc :)
Look at these four pieces of toast. Slightly layered and rotated, but each of those four pieces of toast are the "same" four individual pieces... four separate photoshop layers reused and slightly nudged.
2024 Tacoma Maybe a little bit confused... But Is anyone know where is in the background of Tow Haul mode? 1757654262300-s
2024 Tacoma Maybe a little bit confused... But Is anyone know where is in the background of Tow Haul mode? 1757654272574-r9
I would honestly be shocked if the mountain range was an actual photo, because then some photographer would need to be credited somewhere etc.
chasea1989
Chase
Las Vegas, NV
2024 Toyota Tacoma SR5
It definitely looks like the same picture, just cropped in different ways. And you don't necessarily need to credit a photographer if you either bought the rights to a photo or used a stock photo that's in the public domain.
