Negative wheel offset with 33’s
808fuks
Aaron
hawaii
2025 trd sport bronze oxide 4x4
Does anyone know if I run 17x8.5 -10 offset with 33x12.5 tires and a 2.5”lift, if I need to do any trimming or modification to either side of the fender well?
JuanitoBonito
Juan
Chi-town
2025 Tacoma Off-road, 2026 Honda Passport Trailsport, 1968 Chevy Nova
I have 285/75/17 KO3’s with -10 wheels. I had to do some very minor trimming to the rear bottom tip of the fender and in the front of the wheel well, I had to trim a little bit of the plastic lower fender and zip tie the fender liner back. I still look stock. I can send you a couple pics to show you exactly what I did. It was all very minor. Check a tire calculator because I do believe the 12.5 will be just a tad wider than a 285.
Juan
808fuks
Aaron
hawaii
Juan
Thank you bro. Yeah pics would definitely help. And you’re running a 2.5” lift too?
JuanitoBonito
Juan
Chi-town
For sure, incoming in a few. Yes I’m running the 2&1/2” / 1.5” rear TRD bilstien lift. Absolutely love it!!
JuanitoBonito
Juan
Chi-town
Ok….this is the rear of the front wheel well. Where my finger is, is where I cut. It was very minimal. Maybe 1/4” to under 1/2” total.
2024 Tacoma Negative wheel offset with 33’s imag
JuanitoBonito
Juan
Chi-town
And then the front. Again, very minimal
JuanitoBonito
Juan
Chi-town
Underneath in the same area. You can see where I used a zip tie. I drilled a tiny hole for the zip tie to hold back the felt liner
