T-mat and more installed
mattlee
Matthew
Washington staye
2025 Trailhunter
Happy with how things are turning out. I went with a Tmat system that allows me to move things around, add or subtract as needed. I can also pull it out to access something on it or just remove it all together depending on needs. I made the divider and then realized it was a good way to mount the recovery boards. Some of the mounts, esp the Hi-lift jack mounts are a combination of different ones to make one that worked. I thought about building something and mounting it to the forward molle panel but went the easier way.
2024 Tacoma T-mat and more installed 520816651_10229222800781633_7548561321572287430_n
2024 Tacoma T-mat and more installed 522073551_10229222801341647_204204138626661638_n
2024 Tacoma T-mat and more installed 520158283_10229222801541652_6530262469548444350_n
2024 Tacoma T-mat and more installed 518166410_10229222802181668_1501291075511320892_n
2024 Tacoma T-mat and more installed 518718761_10229222800861635_2669134342558870516_n
2024 Tacoma T-mat and more installed 520415247_10229222801221644_2455988919218428281_n
2024 Tacoma T-mat and more installed 520358990_10229222800461625_3951633157339383152_n
2024 Tacoma T-mat and more installed 521249676_10229222800381623_7715688181786683089_n
2024 Tacoma T-mat and more installed 520307100_10229222801661655_2603034837315976460_n
TX-MD
marvin
AR
Tacoma, 4Runner
Which hard cover do you have? Looks like the 6ft bed? I’ve been debating getting a retractable hard cover on my 6ft bed.
mattlee
Matthew
Washington staye
2025 Trailhunter
I went with the Retrax Pro and yes it’s a 6’ bed. I wanted the option to put a rack on later if I decide to go that way.
