Trailhunter with 35s Rubbing (Need Help)
stuckinsocal
24 TRD OR 6MT
I don't know man, I think you may have too little offset. Stock TRD OR wheels are +55. The more your tire sticks out, the bigger arc it has to go through when turning. Take a look at the below videos for real world fitting of 35s. It's close, but they technically don't rub on a +55 wheel. That said, maybe the hybrid adds something and I'm completely wrong about your application.
alairmore
alairmore
Adam
Tustin
2025 Tacoma Trailhunter
Everything is good now. I rerouted the sway bar disconnect wire above the frame and removed that bracket. I have no rubbing full lock forward and reverse even when hitting bumps and the brakes.
I will hit the trails this weekend and see how it does off-road flexed out 🤞
Arikonarek12
Nick
New York
2024 Toyota Tacoma
Out of curiosity, did you have to remove the crash bracket behind the front wheels to get it to fit?
Also Id love to see some pics with the new wheels!
alairmore
alairmore
Adam
Tustin
Nope, still have about a half inch of clearance even at lock. No rubbing on the road, but not sure if it's enough to clear when off-road. I will test that this weekend.
2024 Tacoma Trailhunter with 35s Rubbing (Need Help) 1763049593818-9m
ArnoldN.
Arnold
Houston Tx
I'm curious how did this play out in the wild?
alairmore
alairmore
Adam
Tustin
Sorry for the late reply; I didn't go out yesterday due to the rain here in SoCal. When out today and did some easy - moderate trails. In a few areas, I was fully flexed out and made it a point to steer lock to lock, with no rubbing.
When angled just right, the clearance between the tire and the crash pad is extremely tight, about a finger's width, but it never rubs.
GTBradley
Brad
Denver
I just installed Method 703s 17x8.5 +35 offset with Falken Wildpeaks AT4W 35x11.5 R17. The driver's side tire is rubbing on a bracket when at full lock, and I hit a dip or press the brakes hard. Has anyone experienced this, and what was your solution?
Can I ask where you bought your wheels and tires? Tire Rack doesn’t seem to be a good option for this size. Thanks
alairmore
alairmore
Adam
Tustin
I got the wheels and tires off Facebook marketplace from separate individuals.
Wheels brand new in box for $1000
Tires 6000 miles with 16/32 tread for $800
alairmore
alairmore
Adam
Tustin
New update:
I hit a few more technical obstacles. Steep hill with deep moguls.
The front-drive side rubbed against the crash pad. I will be removing it.
The rear is rubbing as well, which I didn't expect. There are small bumps in the plastic wheel liner that extend about an inch at the bottom, and the tires rub lightly on them when fully flexed and under load while climbing. I don't think I will do anything about it, they will wear down eventually.
