Victory 4x4 engine cover and Toyota bed Molle panels installed
mattlee
Matthew
Washington staye
2025 Trailhunter
I continue to add things to the truck and this time remove the ARB sport bar. So many modern engines look like crap, ours included. I like the engine cover by Victory 4x4. I had one issue with the Toyota molle panels but that was with the nut setter tool kit I have. The threads were not long enough for the nut included with the panels. The tool kit came with its own nuts and I risked trying those. They worked fine. I doubt I'll be able to use the front panel because I'm getting a Retrax Pro this week.
nurp42
TRD PreRunner
Jeff
'24 PreRunner
Your upgrades look really good(y).
Interestingly enough, when I was deciding which tonneau cover to get it came down to the one you're getting and the Revolver. The main reason I opted against the canister-style was to keep the bed space open allowing for continued use of the Molle panels.
mattlee
Matthew
Washington staye
2025 Trailhunter
Losing the area due to the cannister is the draw back of the top I'm going with. I considered something a Backflip but that limits any rack that I may want to add later. I didn't really look into the Revolver. Maybe I should have. I like your setup.
