Zekzoop-Tacoma Door Molding Trim Available Now!Up to 20% off
Zekzoop
New Jersey
The door molding trim for the 2024 Toyota Tacoma has now arrived at Amazon warehouses.
  • Fitment: The door molding trims are compatible with 2024 Toyota Tacoma, ensuring a precise fit according to the original car design. Note: Only suitable for Tacoma Double Cab 5 Seats, not for XtraCab 2 Seats.
  • Material: Made from high quality thermoplastic elastomer (TPE) which known for its robustness, flexibility, and weather resistance, the door moulding trim could work in both hot and cold weather, protecting your car door from slamming and debris impacts.
  • Function: Door moulding trim protects doors from scratches and impacts during use, reduces the risk of accidental collisions in confined space. It also improves the appearance of the vehicle through textured and edge-reinforced designs.
  • Installation: The installation process is easy, requiring no drilling or special tools. To install the door molding trim, ensure the car surface is cleaned by cloth and dry, then stick the product. For enhanced adhesion, consider using adhesion promoters. Note: Low temperatures(below 10℃/50℉) can weaken adhesion, use the hair dryer to enhance it. Avoid water for 24 hours after taping.
Only $79.99
You can click the link to get it or use promocode "20L71K15"
https://www.amazon.com/promocode/AB...7F33962AF4E9C5_afap_abs&ref_=aa_maas&tag=maas
Vidman
Mass
Can’t get any uglier than that
