- First Name
- Jake
- Joined
- Feb 8, 2024
- Threads
- 15
- Messages
- 140
- Reaction score
- 139
- Location
- Fort Worth, Texas
- Vehicle(s)
- 4th Gen Tacoma
If you're running the new 2024+ Tacoma and planning to wire in lights, air, or other gear, this is a mod to knock out early. The OEM Style Switch Panel from Cali Raised LED is a direct-fit upgrade that replaces the center dash tray with a precision-molded panel built to house the Cali Raised 8 Switch Control System. It gives you clean, factory-style control without any cutting or fab work.
Key Features:
This version is specifically molded for the Cali Raised 8 Switch Control System. If you're running traditional Toyota-style tall switches, check out our alternate 2024 Tacoma switch panel option.
Is this panel just for aesthetics?
No—this is a functional, trail-tested solution for controlling multiple accessories from a central location, with OEM fit and finish.
Clean up your cab wiring and take control of your gear with the OEM Style Switch Panel for 2024+ Toyota Tacoma—built for the Cali Raised 8 Switch System and ready for your next trip.
Key Features:
- Direct OEM Fit – Snaps into the factory tray location using original mounting clips
- Zero Modification Needed – No cutting, no drilling, no headache
- Built for the Trail – Injection-molded from 1/8" ABS plastic, built to take heat and abuse
- Clean Factory Look – Matches the OEM dash texture and layout
- Quick Install – Drops in with minimal tools and gets your cab wired fast
- Fits all 2024+ Toyota Tacoma trims
- Installs in 5–10 minutes with trim tool or flathead
- Designed specifically for the Cali Raised LED 8 Switch Control System
