- First Name
- Rudy
- Joined
- Feb 13, 2026
- Threads
- 13
- Messages
- 257
- Reaction score
- 211
- Location
- New Mexico
- Vehicle(s)
- 2026 Tacoma TRD PRO
I did the Meso, easey peasey, no issues.
Do you still have any issue?Bought and installed one of these weeks ago. Took longer than it should’ve though because it was mis-wired from the factory. Luckily I didn’t have to solder anything
Here's the instruction manual,please check:https://cdn.shopify.com/s/files/1/0...ED_Light_Installation_Manual.pdf?v=1776308533Would you by chance happen to be able to snap a picture of the wire configuration that worked for your light?
If you have any issue,please feel free to contact our customer service team,they will help you within 24 hours.FYI it seems your latest batch isn’t wired properly which is causing issues when installed.
No. I was able to fix it myself.Do you still have any issue?
Silly question but which end did you swap? The big or the little one?Meso and Lexland are very similar. I think Lexland just had a bad batch of wire harnesses sent out. If you don’t want to fix yours, contact Lexland. If not, it’s an easy fix. Just push the black and blue wire pins out and swap locations. I pushed the pins out with needle nose pliers and gently pulled at the same time. Easy quick fix
Big end that plugs back into the Toyota harness in the header. I able to pull the pins and swap on my work bench.Silly question but which end did you swap? The big or the little one?
Should be full disclosure that you're sponsored by, biased, and thus promoting Lexland.I heard they were coming out with a version 2.0 that should fix it. I’ll keep you posted with what I find out.
Hi,please contact our customer service,our team will give you teh solution asap,thanks!I tried installing this today, but the unit didn't work as expected. It would stay indefinitely with the doors locked. If you turned it off, it of course wouldn't turn on when the door was opened. Beats me what is wrong, so I gave up and reinstalled the OEM dome light. I should note that I bought some door puddle lights at the same time and they work just fine.
