TPMS programming second set
Big P
Mr.
Kincardine
Ford Ranger
So new winters I bought (pmc tire) has TPMs installed - but apparently truck doesn’t recognize them yet and have to be “programmed”.
Anyone had success with any cheap obd TPMs tools to reprogram?
Thanks
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
P 543 or 544 in the manual
How to change between
wheel sets (with 7-inch display)
wheel sets (with 12.3-inch
display)
Big P
Mr.
Kincardine
Ford Ranger
display)
Tried that - but these aftermarket TPMs need to be programmed first before they will be recognized apparently.
goin2drt
KY
Thanks
What brand of TPMS did they install? They should have programmed them for your year, make and model before installing? Without knowing the brand of TPMS there is no "cheap" version to actually PROGRAM the sensors. You would need a tire shop that has a fully unlocked TPMS tool that programs all brands of TPMS.
Chances are something else is going on. Not many tire shops install a generic TPMS without programming them first. Then you have to do a RELEARN once installed.
NOTAFORD
Andy
Massachusetts
2024 Tacoma TRD Sport 6' bed
display)
I just went through this with my new tires/wheels with tpms from TireRack. Tried the reset tire pressure and 2nd set as in the truck settings. Did this several times and got some pressure sensing but it would come and go. Finally I saw in manual where it said to do the reset and drive 10-30 minutes at 25-35 mph and that worked. No programming device needed. I only drove a few minutes at that speed and it worked. Maybe do a few careful snake turns while driving which the manual also mentions to help locate new wheel position. Hope that helps.
kenekim
Ken
Florence SC
2024 Toyota Tacoma 4X4
I put 20" Tundra Wheels on mine, I bought 4 new TPMS from eBay(tpmsdeals) $89 set already programed. stopped at a Walmart parking lot and read the manual and before I got home they were reading properly
2024 Tacoma TPMS programming second set IMG_2153
2024 Tacoma TPMS programming second set s-l1600
