Hood insulation
Gfenza89
Gary
2022 tacoma sr5
Can you elaborate more on this rubber stripping on the rear door, I like to reduce all noise.
Go to your local Toyota dealership and look at some higher trims, you’ll see the gasket I’m taking about. That’s gonna be the best way to see it, you can also order them from your dealerships parts department
bresna
2024 TRD Sport
Ordered the OEM insulation and clips yesterday. Got everything for ~$250. Will report back after I install it.
Where did you find the insulation and clips for $250? Most places want at $300 just for the OEM insulation.
Wahhabm
Monther
I imagine Toyota had a black Friday sale.
Garrett
NC
They had a sale running. I see them fairly regularly actually.
2024 Tacoma Hood insulation 1736177218899-el
Slappy
tacoma , highlander
So is that thin black strip visible with both door closed ??
Love to see a close up detail photo that shows the shape of the seal . I guess i will go over to the dealership & see if I can find a model with the seal
Wahhabm
Monther
Thanks for the photo. It seems some aftermarket weather stripping can work also.
I just went to the dealer and they provided part numbers below. There is actually 4 of them. 2 on front door and 2 on rear door. Yes, they are visible when the door is closed.
67895-AK010
67896-AK010
67865-AK030
67866-AK030
the dealer wanted $26.+ for each plus tax amounts to $114 roughly. I decided to wait for when toyota offers a sale.
Slappy
tacoma , highlander
67895-AK010
67896-AK010
67865-AK030
67866-AK030
thank you !
i'll pick a set up
Yep - you can see them when the door is closed - they just fill up the gap between the panels and I never really notice them. There is also a gasket between the back of the cab and the front of the bed, but I don't know which trims it comes on.
That's not bad at all. Considering the price for the hood blanket it is almost free.
Wahhabm
Monther
67895-AK010
67896-AK010
67865-AK030
67866-AK030
I am doing a follow up on these part numbers. All 4 parts arrived today The 1st 2 parts 67895-AK010 and 67896-AK010 fit perfectly on the front edge of the rear doors. However, the other parts don't fit on the front door. It seems the dealership gave me the wrong numbers. The correct numbers should be 67865-AK020 and 67866-AK020. I hope everyone gets to read this before they order the wrong parts. Honestly, I don't know where those are supposed to fit. If I trim them, I can add them to the area where the rear door closes to, it seems, I can make them fit that area with some trimming.
2024 Tacoma Hood insulation 20250117_103135
2024 Tacoma Hood insulation 20250117_103345
2024 Tacoma Hood insulation 20250117_102752
2024 Tacoma Hood insulation 20250117_101925
Cabo
Pacific NW
2025 TRD Off-Road i-Force Max
New to this group, first post. I’m confused. Just received my 2025 TRD OR I-Force Max (not “premium” package so no hood insulation pad). My dealer says the Hood Insulation Pad (53341-AK010) “should” be compatible but is $475. Found cheaper at multiple OEM outlets online but none will confirm fitment for 2025 model, but all show fitment on 2024 models. Has anyone added this to a 2025 Tacoma OR yet? Thanks for any assistance.
BAQ717
‘24 Tacoma TRD OR
53341-AK010 is indeed the part # and I’ve installed on my 2024 without issue. I can’t imagine it wouldn’t fit on a 2025. Don’t forget the clips when ordering. 90467-A0003, you’ll need 10.
