LIMITED Hybrid Max folks: How is the FT 4WD?
CurryBob
Bob
Alexandria Alabama
2024 Tacoma Hybrid Limited- 2025 Lexus ES 300 Hybrid- 2023 Lexus RX 350 Hybrid
Mine is great, no issues. I have the stock Michelin tires.
Any info on whether the 4WD system will put up with different size tires ?
On my wife's AWD Highlander, an unrepairable flat means I have to purchase four new tires because they can't be more than 2/32 different. Big $.
Don't have that problem with my 2nd gen Tacoma with old school part-time 4WD.
That's too vague a statement.
If the wear life of the remaining three is close enough to new, it can be a single swap. If it's just outside you have to do both on that axle. If it's more than halfway (iirc) you have to all four.
Speaking from owning a Toyota AWD/F4WD for 20+ years.
When this did happen to me, I would always have the shop compare the good take-offs against the spare, and if the rubber or tread was better, update the spare. This had a few benefits: spare was periodically getting a "health check" (rubber crack/brittle, tire pressure, valve stem, etc), spare had slight wear so it was a better fit rotationally when needed, make sure the spare was periodically dropped and I wasn't going to have something stuck and inoperable when I needed it most.
CurryBob
Bob
Alexandria Alabama
Yeah, they do contracts with different brands. I was hoping for Michelin's and got lucky, which is usually not the case. Lol
I'm also wondering if the rough ride that happens between 36-43mph is related, even though I had a tire shop remount and rebalance the OEM tires...
dholmq
dholmq
Darren
Central Oregon Coast
2024 Tacoma Limited Hybrid (Blue Crush)
Thanks for all the replies to my thread. I now have a Hybrid Limited with FT-4WD in blue crush. Holy sh*t the driving experience is so much better than a non-hybrid limited. This thing sticks to the slick ground. Drives more like the Land Cruiser (probably due to same engine/FT-4WD) I love it!
Ron
Samsara
Put some proper tires on and it gets even better !
The full time 4WD is standard on the new Land Cruiser, which tells me it is very capable on and off road. The reviews for that system in low traction situations are all very positive. That makes me wonder if they will transition other hybrids from part time 4WD to full time eventually.
Chuck
2024 Limited hybrid
My Limited hybrid has that same behavior. Rough ride/shaking at 36-43mph. Can feel it in general in the whole cabin area but not much travels through the pedal or steering wheel. Not very noticeable if I accelerate quickly through that mph range. The truck came with General “Grabber HTS 50” tires and has only about 500 miles on it. Haven’t taken it back to the dealer or anywhere else yet. Other than it’s my first 4WD (my last was a 2WD Tundra) and I’m liking the truck more and more every time I drive it.
Same trim, same stock tire. Same feedback on how/what the vibration feels like.
Please keep me posted if you learn or figure anything out!
KeithB
Keith
Cheshire, CT
2026 Bronze Oxide Limited i-Force Max Hybrid
Same here. LMTD HV with general grabber hts 60 tires. Can feel a shudder that I thought was engine lugging at low rpm but even with my foot off the gas pedal I can still feel it. Could it be tire related? Only have 700 miles on it so far.
rkohlerbend
Rob
Bend, Oregon
2024 iForce Max Limited
Mine works seamlessly at 6K miles. I have Falken Wildpeak AT4W 275/60R20 tires.
