tacosinnataco
Sep
Bay Area, CA
I don’t think I would want any more poke. The only thing you can do is take off the crash plate, then you can go to 35 no issues. I used to be a 35-or-die guy but honestly 33.2-33.5 is really plenty and is a nice compromise. They don’t look small and ground clearance is solid. Just my 2 cents.
I meant 285/70/18's btw LOL
As for the offset, I was referring to increasing it to move them inboard. Lowering the offset would move them outboard and would probably cause contact.
Ah yes, positive offset. But how would that make larger tires easier to fit? You’d probably bump the UCA. The real issue will be the rear of the tire making contact with the crash plate and the mud flap.
That said the wheels all come with slight caster position deltas and you may be able to get 285/70/18s on — typically that’s a 33.7” tire. My own observation is that around ~33.5” is the limit which translates to a “big” 275, and my Falkens are a good example of that.
VermontTaco
VermontTaco
Vermont
2024 TH Ice Cap
Those look great on the TH. Perfect size
Eco-nomadic
Ian
Tennessee
2024 Tacoma SR5
The stock 17” rims can fit a 34.0” x 10.50” tire without any rubbing but that would be the narrower size allowing that bit more clearance.
The positive offset would help by keeping the tire closer to the body so it wouldn’t swing as wide, potentially rubbing on the crash plate. That being said, the TRD Sport 18” rims with a +55mm offset instead of the +20mm on the Trailhunter still max out at 275/70R18 without potentially rubbing on the crash plate.
Eco-nomadic
Ian
Tennessee
2024 Tacoma SR5
This video shows how the positive offset can be beneficial for fitting larger tires.
TacoRyno
Colorado, USA
2024 Toyota Tacoma TRD Sport
Really liking the KO3's so far. I only have 100 or so miles on them, so this is really an early / high level review. Some context before getting into more details - I live in the northeast in a snowy area, and was considering a few different options in 275/70/18 before settling on the KO3's:
  • Ridge Grapplers
  • KO3's
  • Toyo open country 3's
  • Wildpeak A/T 4's
For me, the KO3's represent a great combination of off-road capability, on-road comfort, snow performance and overall appearance. I know that a few of the other options may perform slightly better in the snow (like the Wildpeaks), but after talking with some guys around my area that have tried these tires, everyone agreed that the KO3's were strong enough snow performers.
Because I've had them for less than a week, I haven't had a chance to get them too dirty yet, but I expect they will perform well. More to come later once I get off-road.
On-road driving is good and getting better now that I've dialed in the psi. The installer set my tire pressure on the high side and a bit random - I had one at 44, one at 39, and two at 42. The initial ride felt generally good, but with some vibration and bouncing at various speeds. A little rough out of the gate TBH. I brought them down to 37 and the on-road ride feel really improved, nearly the same as the stock wranglers. I'd like to go a bit lower and likely will when we get more snow.
Acceleration seems about the same. I'm not too far past break-in, so I wasn't really hitting it hard before the swap so not the best comparison. But living and driving between 2-3K feet in elevation everyday, the turbo seems to be doing its job well. Not much different from stock so far.
Coasting on the highway seems about the same, not a lot of deceleration when laying off the gas. I still need to better measure MPG, I assume it will be slightly worse by 2-3 MPG.
I did ask the shop to see if this size would fit in the spare compartment, but they weren't able to. This is snow tire swap season, and these guys are working like crazy so I didn't want to push them.
Overall appearance? I really love how they look. This size seems to be the right fit for TH's. But that's just my thinking, opinions may vary. Pics below.
The THs bronze wheels are so freaking sweet. Thanks for the close ups!
NMTacos
J
Abq
  • Ridge Grapplers
  • KO3's
  • Wildpeak A/T 4's
Howdy, nice ride! I'm a proud new TH owner and wanted to get the RB mud flaps too. However, according to RB, they won't fit the TH....Based on the pictures here, it looks like yours fit just fine. Any insight you can offer concerning fitment, issues etc?
If your fitment solution is easy enough, I'll pull the trigger.
Btw, I talked to RB and they said they're developing a new hardware kit for the Pro and TH models.
Thanks!
VermontTaco
VermontTaco
Vermont
2024 TH Ice Cap
Thanks!
Hey!
TBH, I had no clue that they didn't fit the TH until long after installing them. I missed the disclaimer on the order page.
Install was super easy, but perhaps I got lucky. Since I figured out that they aren't supposed to fit the TH, I do notice inside the wheel well that it could be a neater more clean design. Might be worth waiting for the TH version though.
Rope_photo
Jared
'24 Tacoma Trailhunter
Does anyone know if a 285/70/18 will fit under a Trailhunter in the spare location?
NMTacos
J
Abq
Hey!
Ha! Well, they look pretty great in the pictures. Nice job getting them to fit. Thanks for the reply!
BearTacos
West
Central Indiana
Me too. We just need to get some snow...
What PSI are you running?
Do you have any updates on your K03's after a Vermont winter? I'm looking to upgrade my stock tires to the Toyo AT3, K03 or give the Duractrac another try ( wasn't happy with the redesign on my F350 , they seemed LOUD vs the old style)
MHG
Mark
Long Island
2025 TRD Offroad
  • Ridge Grapplers
  • KO3's
  • Wildpeak A/T 4's
I am surprised its that close on a trailhunter. If I am not mistaken they are 2.5" higher in the front than the OR. Would have thought that roughly 3/4 of an inch in tire size change would not have been that close.
Nic looking ride though
Castor varies on these trucks to the point that many can throw on 34.3” tires with no issue while others get super close on 33s. I’d love to get the castor specs so an alignment shop can dial that in for us
Reactions: MHG
VermontTaco
VermontTaco
Vermont
2024 TH Ice Cap
Thanks.
Surprised as well. To be fair, those mudflaps are not supposed to fit on the TH. I made them work. With a properly designed mudflap, the fit is likely much better.
GDTRFB
Ryon
Idaho
2025 TRD OR
  • Ridge Grapplers
  • KO3's
  • Wildpeak A/T 4's
Did you ever try to fit a full size spare under the truck? If so, how did it go?
