Dash trim removal? Blue trim wrap or paint.
Groot88
Caleb
Orlando FL
2024 Tacoma TRD Off Road
I am not a fan of the bright blue trim on the door panels or dash in my new tacoma and want to do something different. Anyone know how to remove the main trim surrounding the 14" touchscreen? I took a stab at it and not sure if the screen needs to be removed? If so how is that done? Every other trim piece came out with ease, but I'm not wanting to break or damage anything in the process. Can't find anything online, Pictures and or video would help! Thanks.
Btimothy4
TB
Denver
I have had mine off
The doors, you slide them towards the font of the truck. I start at the edge of the door and just push towards the dash and they come off. They will break if you use the trim tool
The piece on the right of the dash comes up with a pry tool and yes, you will have to pull the stereo to get to a screw that holds the larger piece in. They are easy to wrap in vinyl yourself or a shop. I would recommend vinyl over paint, gives you lots of options to change it to and the ability to return it to stock
Groot88
Groot88
Caleb
Orlando FL
Thank you for the info! How do I go about removing the 14" display screen to get to said screw holding the dash trim down?
Front door trim seems to slide right off like you said and got those off easy, but I haven't been able to take off the back door trim. Any specific location to pry from on the back door trim?
Deleted User 1813921
Guest
Taco Tunes 2024 Tacoma powered subwoofer install video on you tube has demonstration of 14” screen removal.
2024 TRD Sport-Bronze oxide.
I've got a Bronze oxide Sport and for the life of me can't figure out why some nut case thought it would look cool with bright white accents inside. If they would have just been a grey or dark silver, I wouldn't have given it a second thought.
Groot88
Groot88
Caleb
Orlando FL
I'm definitely going to wrap mine. It's the bright blue color trim on mine. Trouble is getting the trim off. I have the two front doors figured out and the trim to the left of the steering wheel, but the back two doors and trim around the screen are giving me trouble.
TheOldObiWan
Josiah
2024 Taco
I would love to trade you. I’ve got the dark silver trim and I’m in a white TRD offroad
Does anyone know how to take the rear door trim off?
TheOldObiWan
Josiah
2024 Taco
Okay so the back door trim piece comes off by removing 5 T20 screws from the back of the door panel. You have to remove the whole panel which wasn’t all that difficult.
2024 Tacoma Dash trim removal? Blue trim wrap or paint. IMG_4561
2024 Tacoma Dash trim removal? Blue trim wrap or paint. IMG_4562
Viper_00
Walter
VA
Instructions on how to remove dash bezel
2024 Tacoma Dash trim removal? Blue trim wrap or paint. IMG_6070
Viper_00
Walter
VA
You’re welcome
KrisM3
Kris
PA
2025 Tacoma TRD OR H
I know this is an old thread but did you happen to notice a valid part number on that rear trim?
Jose
Orlando, FL
2024 Toyota Tacoma Limited,
I have had mine off
thank you so much
