Viper_00
Walter
VA
I took a chance on this 7” bar and it worked. How long it will last is tbd?? So I just centered it and then ran the wire to the AUX 1 location inside the engine bay next to the coolant reservoir.
Nilight Slim LED Light Bar 2Pcs 7... https://www.amazon.com/dp/B0CV39BFR1?ref=ppx_pop_mob_ap_share
Viper_00
Walter
VA
Did you need to remove all the hood scoop components and drill a hole for the wire I would suppose?
I wonder if this one would fit which is the same model but is 10" instead of the 7".
https://www.amazon.com/dp/B0CV3H8RJD
That may fit but without the brackets. You would probably have to use double sided tape. I did take the scoop off and drill a hole for the wire to run through. It comes off easily so if you end up getting the 10 inch and it works then let me know.
JimScotty0
The Farm, Central Washington
2024 Toyota Tacoma
This one looks interesting too and with Amber. It might be tight and not using the brackets.
SAMMAN 10Inch LED Light Bar 78W Yellow Spot Flood Combo Beam Driving Off Road Bar Fog Light for Truck Pickup Jeep SUV ATV UTV 2PCS
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 1745208640134-r8
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 1745208691694-ji
2 for $35.99 78W https://www.amazon.com/dp/B089SS4DVM
I would prefer the Nlight as they are a tiny bit smaller, but they only have them in white, not amber which is what I would prefer. I don't think either of these are for street legal usage.
Viper_00
Walter
VA
Yeah that’s why I went with the nilight. The cavity inside the scoop is tiny. These definitely are not for street legal use but it’s worth a try. Not hard to attempt.
Viper_00
Walter
VA
So I took a chance with this light bar and it fits like a glove. I just used double sided tape on the bottom of the light bar. Also while I had the engine cover off I went ahead with my left over sound deadening and applied it underneath. With the added weight of that plus the light bar it did minimize the infamous hood shake. Not ? but definitely much better. Anyways thanks again with this link! Idk how I missed it.
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop IMG_5670
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop IMG_5669
JimScotty0
2024 Toyota Tacoma
How do you find the brightness of this light bar? Is it something that can be used for regular DRL, or should it be on a separate switch for usage when necessary?
Viper_00
Walter
VA
It’s bright for what it is for sure but yeah it needs to be on its own switch. I hooked it to aux 1
JimScotty0
2024 Toyota Tacoma
I am going to give this 2 power Amber one a try and use the low connection with my other DRL lighting. It also has a High Brightness mode too which I am not sure how I will use that. Perhaps on my switch when needed.
For $13.99 it is worth a try and it should also fit without any trouble. https://www.amazon.com/dp/B0CHJD2RFL
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 1745540096983-r
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 1745540288285-h0
Dansflhti
Nova Scotia
If I was doing a light install in the scoop.....I'd be so tempted to paint or wrap the scoop black while I had it removed from the hood.
