Scratches on multi-informational screen
Zanez
Zane
Cali
Running into a lot of scratches on both of my screens. Has anybody ran into this and does anyone have a fix for it? Thanks in advance
Nacho TacoMan
Paul
2025 Tacoma Limited. 2018 BMW X5 335d
I installed the Screen Protech kit on all scratching surfaces. It’ll also cover up the current scratches as well. Watched videos (they insist before installation) as I have never done any kind of installation myself and it came out really good. I’m very pleased with the product and my installation result.
Zanez
Zanez
Zane
Cali
Awesome! Where did you get this kid at?
Wighty
Rob
OC, CA
2024 TRD Pro
I'd try polishing out the scratches and then pout the screen protect on.
Darkhorse24
NC
“Multi-informational”…are “we” trying out new nomenclature for the Toyota lineup? Every manufacturer calls it either a multimedia radio, headunit or infotainment (thanks CJD)…
to answer your inquiry: there are numerous companies that have screen protectors esp Gorilla Glass but it’s the dashboard that most people seem self conscious about since it can be noticeable during the day.
Novus Plastic Polish, Meguiar’s PlastX, or Mothers Plastic Polish
Use a plastic-safe sealant or protectant (like Plexus or Meguiar’s Interior Detailer) to reduce future scratches and UV haze.
• Harsh abrasives (toothpaste, rubbing compound) — these can dull or distort.
• Power buffers on thin clear plastic — heat/friction can melt it.
• Alcohol/ammonia cleaners — may cloud or crack over time.
Zanez
Zanez
Zane
Cali
Sorry about not stopping to look through my manual for the technically correct name for the display system. I figured everyone would gravitate to the meaning when I wrote this. Thank you for the advice.
Darkhorse24
NC
Honestly,
Honestly, it kind of threw me since I work at the dealership… if you’re talking about the radio, that’s fixable but if you’re talking about the dash with the speedometer and tach, that’s not as easy since it’s smaller and tighter plus a lot of times, the local dealerships leave the plastic that came from the factory on it so the scratches may just be on that and not on the surface itself. So make sure you cheek for film before you start any surface scratch repair.
Zanez
Zanez
Zane
Cali
Honestly,
I did check but it had been removed.
Darkhorse24
NC
At least someone did their job. Speaking of which, have you noticed in your drivers side, whether driving or when you shut your doors on that side, it sounds like there is something loose behind the cab but near the gas tank? I don’t but im starting to hear a lot of owners mention it and I have a meeting with our service dept Monday about that and any other issues
RyJarc
Utah
2025 TRD Tacoma
Honestly,
I am confused also, never has it been called a "multiinformational...." Oh well, moving on. I've owned over 79 different trucks, cars, and motorcycles (let's just say vehicles). Not once has the plastic or whatever you want to call it that covers the odometer, etc, ever been scratched. This doesn't add up. How's it getting scratched? Scratching it with rocks or using abrasive cleaners or rags? I'm just curious, honestly. The only thing I clean is the plastic that is covering that, is literally do with a Swiffer to get rid of dust. Or, if for some reason one of my kids decides to touch everything, I'll use a microfiber cloth. No, chemicals needed.
Slappy
tacoma , highlander
Swiffer . . . . . . What a Great idea !
been looking 4 how to clean off the dust without doing a spray & wipe , as that just grinds dust into the lens with long scratches & the cleaner clouds the plastic .
I will use my air compressor hand nozzle gun to blow the lens off & then use a Swiffer to get what is left . Been waiting on a idea to clean that lens b 4 installing my lenz protectors on the speedO & infotainment screens .
ThanX
Life is easy , ya just gotta b smarter than the Equipment
RyJarc
Utah
2025 TRD Tacoma
ThanX
Sorry, I was not referring to Swiffer with the liquid.(Yeah, don't do that.) I misspoke. I'm referring to the duster only. Swiffer is also the brand. No liquids. Any soft duster works excellently. I keep it in my glove box and use it as needed. I'm not referring to the floor mop thing made by swiffer. My mistake!
