Reset just radio part of infotainment system?
emerica243
Matt
PA
Fusion
Sirius subscription expired and all of my favorited stations are taking up the full alotment. So i cant add normal FM radio stations as favorites now. And you cant remove\delete the sirius stations because you cant get into them far enough to remove them as a favorite because you have no subscription. Dumb design. Any ideas how to reset only the radio peice? Im not trying to reset the whole infotainment system and lose any other settings ive made.
Gator Hunter
Melbourne, Florida
Good morning Matt. I ran into the same problem, I hope someone has a solution. The only thing I think we can do is join Sirius for a free promotion and then clean up the mess. Thanks.
N3rby
Ivan
Bc Canada
2024 Toyota Tacoma off road
Hey fellas if you go to your favorites tab, then tap on any one that will allow you to go to where you can see them lined up on the left there is a little blue button with edit above all the favorites click that the you should be able to delete all the ones you don't want. Let me know if it makes sence if it did not I can take some pictures.
EastonTaco
Venice FL & Easton PA
Just remember you have to be stopped and in Park for the edit button to be visible.
emerica243
Matt
PA
Fusion
Great Scott youve solved it! lol. Figures, i was only doing it stopped at a light, not in park. Wouldnt even know that EDIT button was a thing since its invisible unless youre in PARK like mentioned.
THank you much,
EastonTaco
THank you much,
If you knew how long I did the exact same thing as you LOL! One day I was sitting in the truck waiting for my wife outside of Costco and stumbled upon it. It was close to a religious experience 😲 :crazy:
