Installing MTM on a 2024 Toyota Tacoma TRD Off-Road?
mercerd
Darius
Delano, MN
2024 Toyota Tacoma TRD Off Road M/T
Hi everyone,
I recently bought a 2024 Toyota Tacoma TRD Off Road from CARVANA and to say it's barebones is an understatement. I bought it because it was a manual transmission. I'd like to start adding some of the features and I am wondering if this group could help me/point me in the directions of what parts to order to take my backup camera system to a full MTM system. I look at the parts list and overwhelmed because the camera system has so many variations.
Thanks in advance
Yotota
SW WA
24 TRD
We could pull all the part numbers and find every part you need, but...
It will be cheaper, easier, and quicker to sell your truck and buy one with the TRD Premium Package. Seriously.
The only other option would be to find a wrecked TRD with the premium package and pull all the parts you need. I bet that would still be over $4k in used parts after you add up the head unit, modules, cameras, wire harnesses, etc, etc...
mercerd
Darius
Delano, MN
Thanks for the response. I had a feeling this was going to be a monumental pain in the ass. Getting a Manual Transmission was already a pain, and that was my primary objective. If I knew the list of equipment, I could start purchasing slowly over time so my pocket book isn't getting hit all at once.
Yotota
SW WA
24 TRD
You are going to need to pore over all of the electrical parts diagrams to find parts that are specific to the TRD w/ Premium package. The MTM runs on the 14" display, which then requires a full retrofit of the entire audio system to JBL spec. Then all of the wire harnesses that are unique to that spec, cameras, modules, etc.
Like I said... I wouldn't even attempt it. Swapping the wire harnesses will require you to gut your interior down to the bare cab.
But if you really want to dive into it:
https://partsouq.com/en/catalog/gen...8AAAAACme3_x$&vid=0&cid=4&cname=Electrical&q=
mercerd
Darius
Delano, MN
https://partsouq.com/en/catalog/genuine/vehicle?c=TOYOTA00&ssd=$*KwH0wNHrjPWPhoOdg5Xt8qy4mJ-B8P_y8-HO_bWzgJSIjI6NyN_zmbezt4aQiZjew8n0_ZSAhYiNg-H_zb3ltOP85Zrgs7Pu5P30vLixqabf6q-lpOL75uX29aultfbl7OHkrrTgpbGvloaSgIvl7OK9_O7k_eDjkp2Og6ukweuXkpuVnYHgs7GvsKTi--bl-fOtxq_q5-Knr6Pi-L-m8AAAAACme3_x$&vid=0&cid=4&cname=Electrical&q=
Thank you so much. I already have the 14 inch screen. I found the camera parts but as I look at it, I will also need to update my grill, the rearview light/camera assembly, side mirror assembly just to name a few....
2024 Tacoma Installing MTM on a 2024 Toyota Tacoma TRD Off-Road? 1749491804523-v7
Yotota
SW WA
24 TRD
I forgot that the 14" JBL system could be included without the Premium Package!
Now the big question is which wire harnesses your truck has. This could be much easier than I thought.
mercerd
Darius
Delano, MN
How would I figure out what kind of wiring harness I have?
mercerd
Darius
Delano, MN
@Yotota, I did some digging and even tried to reach out to my local dealership to try and get some answers. I asked for a build sheet on my VIN and another VIN that had the upgrades I am looking for but the dealerships were not very helpful.
I think the first thing I am going to try and upgrade will be the digital rearview mirror with the High Mount Assembly.
Mirror: Part Number 87840-0W410
High Mount: 81006-AK020
Any thoughts as to why that wouldn't work?
Yotota
SW WA
24 TRD
Thanks,
Darius
Will they bolt in? Absolutely.
Will they function? Um........
You'd need to dig around to confirm what which wiring harness(es) those parts connect to, and if your truck has them or not. Also, whether or not any other modules or additional parts required. You may get lucky though, since much of the Digital Mirror functionality is built into the mirror itself.
One check you could do on your truck is to see if there are any plugs at the mirror, and the High Mount, that these could plug into.
