Wire tap schematics for the daytime running lights and yeah, turn signals.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Does anyone have a wire schematic for a 2024? Toyota Tacoma off-road that shows which wires to tap into for the daytime, running lights and turn signals.
BIGPZA
Michael
Long Island, NY
2024 TRD Off-Road
The box you want is located below the dashboard on the passenger side of the cabin. This box contains fuses for lights along with most of the cabin electrical components. The trouble with this box is it sits right against the plastic shroud below the dash. I tried to tap into this box and gave up because the only solution I could come up with was cutting a small square in the plastic shroud to provide the clearance the fuse tap needed. I tapped into one of the IGN fuses in the driver side fuse box under the hood. Serves the desired purpose, although now whenever the truck kicks on for diagnostic stuff, it turns on my marker lights briefly. Does it work? Definitely. Is it far from ideal? Also definitely.
Your lights are turning on because you tapped into the IGN fuse. You should be using the INJ fuse IIRC.
Anthony
Aberdeen Wa
I'm not sure you understood my question, I have not hooked up the lights yet.
My question is, I am looking for the daytime running light and turn signal schematic so that I can tap into those wires.
I understood your question, but I wasn't replying to your question. I was commenting to the other person's post.
There are people around here who have purchased the service manuals, maybe the wiring diagrams are in there. Per the post that I was commenting on, the majority of people are tapping into the fuses that control DRL/turn signals and using those.
