Can't find replacement bolts for front recovery hooks
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
Did you order some?
I did not but the ones they posted are not the same. Looking up the part number you posted, look to be right, hard to tell. I got lucky and got a second recovery hook from someone who replaced his and used my original bolts.
Slikka
Michael
Louisana
2024 tacoma
Actually the ones i bought were right in the photo??
Pappy
Albuquerque, NM
The difference between what you showed (which was the part number I shared) was the bolts I took off my truck were self tapping.
Slikka
Michael
Louisana
2024 tacoma
The picture i posted with the bolts are the correct ones ?
Jeff007245
Joeffrey
Los Angeles, CA
2025 Toyota Tacoma TRD Pro
My 2025 Tacoma TRD Pro didn't have the OEM tow hooks installed. I myself and several dealerships are now having a difficult time finding the correct bolts part number. There are several part numbers popping up, but I want the OEM ones specifically.
Please assist as the 90119-A0439 doesn't seem to have the taper of the original.
Could the 90119-A0481 be the correct ones?
TacoBirdinNW
2025 DCLB SR5
For what it's worth the OEM bolts on mine stripped the threads on the truck when I installed Westcott hooks. Had to re tap and install a longer/stronger bolt from Tacoma Screw. Dealership was absolutely zero help. Boggles my mind they can't find simple part #s or solutions.
