Added a Tune M1 to the OR!
taco_overlander
east coast
tacoma
i bought the truck to be a North America adventure machine. the tune m1 was in the plan since 2023. sharing here because I am super excited to get the travel adventure rolling.
2024 Tacoma Added a Tune M1 to the OR! IMG_2676
bluecrush.taco
Seattle
That's so sweet. I've been looking at the Tune M1 for a long time. It looks like a great pop-up camper without the weight of a slide-in. I think it's totally worth it if I was traveling more and living out of it. But definitely on the expensive side if you're just using it for a few weekend trips out of the year.
How's the gas mileage with it on?
taco_overlander
taco_overlander
east coast
tacoma
pricey. no doubt. i am likely to get 180 nights in it this year. so it was worth it for me.
Mileage TBD. for the first 6K on the OR hybrid w/o the Tune, i was right at 23 mpg. today on the 150 mile drive home, the on-board system said 21.5 mpg. i have a light foot. most folks are seeing a 3mpg hit with the Tune. so i was expecting 20 mpg and feel like i will hit that number over the long haul.
for pop-up, my second choice was the Hiatus--which is right in your backyard.
t-rex
Terry
Tacoma Off-Road
What are your update thoughts on the Tune? Still loving it? Do you have an updated MPG? Do you ever take it off?
taco_overlander
taco_overlander
east coast
tacoma
i love it. i am on day 81 of this first North America road trip. left the mid-Atlantic on July 2nd, across North Shore of Lake Superior to the Olympic Peninsula, then north (Vancouver Island, northern BC, Yukon, NWT) to the Arctic Ocean. then back to BC for a month of steelhead fishing, where I am now. we move slow and try to keep the distance moved to less than 150 miles a day. 9907 miles so far. 487 gallons of gas. so that is 20.3 mpg. i get 20mpg because i drive slow. i search out back roads, preferably gravel, and hate highways. The truck is near its GVWR. I have a Taruca awning hanging off one side and a Taruca shower off the other, so the aerodynamics are even worse than just the Tune. I did add Timbren bump stops to get rid of 2in of rear sag--they leveled the truck and definitely help the coils. of the nearly 10K miles, i'd say maybe 4K has been gravel/dirt/double track. the Tune has definitely taken a pounding. it is a joy to live in. as for the truck, i am definitely loving it, even more than the Tune. the suspension has been great, especially considering the load. i never thought i'd use the front sway bar disconnect so much. the 2400W inverter charges the camper battery in about an hour--which we do sometime during the day when driving. attached are the OP-to-Arctic route we took and an updated photo of the truck.
2024 Tacoma Added a Tune M1 to the OR! Image 9-13-25 at 6.11 PM
2024 Tacoma Added a Tune M1 to the OR! IMG_4430
t-rex
Terry
Tacoma Off-Road
Oh woWwww!! That looks like an amazing trip. That would be my dream! The front sway disconnect and the 2400w charging seem awesome, but I was hoping to get the base OR to get the 6' bed. Hopefully the non-hybrid version can be good on MPG if I drive slowly as well.
So you added Timbren bump stops but did you change the coils to Dobinson's or something else or running stock?
taco_overlander
taco_overlander
east coast
tacoma
if i could get my same truck with a 6ft bed, i'd definitely do that. but OR + premium + 6ft bed was impossible to find in 2024 when i wanted to buy the truck.
i am on stock suspension + Timbren. i spent lots of time reading about folks who swapped out for the Dobinson. in the end, i was not convinced i'd get it right. also, i was (and still am) pretty happy with the suspension. but the rear sag was ugly, was definitely undersprung, and i was concerned i might bottom-out the rear on the wavy double track roads i am on about every day. i am not rock crawling. i am just often on rough/washboard/rutted dirt roads. so i started with the Timbren to remove the sag. as a bonus, i gave the coils a bit of help. and i liked it. it was cheap, easy to install, and pretty much zero risk of ending up with something i liked less than when i started.
i love the truck and intend to do these multi-month adventures every year, so i am not against dropping a few $K for a full suspension upgrade. and might do that at some point. but it is definitely not a must-do right now.
and maybe everyone knew this except me, but the gen4s allow the front sway bar to disconnect in all drive modes, including 2WD. it automatically reconnects when the speed hits 19 mph. it is a small thing, but nice when I am on the rollcoaster double tracks that lead into most every rec site in british columbia.
t-rex
Terry
Tacoma Off-Road
Yeah that truck does not exist either in Canada. That is why I will go for the more basic OR to get the 6' bed. And sadly in Canada it seems that only the pro or trailhunter can get the sway bar disconnect which sucks because I would have liked to have it.
So with the Timbren's if it reduces sag it means that when parked the body is already pressing down on the timbrens. Is that right? Because otherwise a bump stop should just engage when the suspension compresses a lot.
taco_overlander
taco_overlander
east coast
tacoma
correct. the spacer towards the top is optional.
2024 Tacoma Added a Tune M1 to the OR! IMG_4608
Mitch33
‘24 Tacoma OR
Do you remember which Timbrens you got? I've got a wedge camper being built that's about 400lbs on its own without all the additional gear so I'm thinking these would be a good idea. Also how do you feel about ride quality with them on? Any significant changes?
taco_overlander
taco_overlander
east coast
tacoma
These are the Timbren SES. Ride quality is good. Definitely much better than without! As I mentioned above, I am at GVWR when fully loaded, so the rear coils can use any help they can get. For the money, I think that this solution is hard to beat.
Running at GVWR with stock suspension + Timbrens works. At least right now. Overall, I would say that it is undersprung and undamped. That is probably obvious to folks who know suspensions better than I do.
In mid-May, I am heading back to BC/Yukon/AK for another 3 to 4 month trip. I am looking into upgrading the suspension. The suspension aftermarket seems like a labyrinth to me. Just like it did last year when I looked into it. So, who knows, the Timbrens could be what I take with me again this year.
