Floor Jack Advice/Recommendations
Goriders
2024 Tacoma Sport Plus
Hello there.
I’ve always had summer and winter tires for my vehicles. With my new truck it’s the first time I have had dedicated rims for each set.
As such I plan on swapping out my tires myself go forward. So I’m in the market for a good floor jack. I’m looking for some advice as there seem to be a number of options out there.
Main questions would be 2 vs 3 ton capacity and max lift height. I’m guessing for just changing tires a 2 ton jack would be sufficient but a little worried about the max lift height on most of them. So might go with a 3 ton to be safe.
Any advice would be appreciated.
NewtoToyota
Georgia
24 TRD Sport
Gurvy522
Chicago, IL
I have a 2-ton Arcan that just barely gets high enough to get the wheels off the ground, when jacking from the frame. It's a low profile model that I use for my other car, was one of the few jacks that would get underneath it as it sits pretty low to the ground.
I did have to buy larger jack stands though, my 3-ton ones didn't go high enough. I ended up with some 6-ton ones from Harbor Freight that did the trick.
For a floor jack, to make it a bit easier if you're close, I just throw a hockey puck between the jack and the frame. Given you're from Calgary, I'm sure you must have tons of those laying around :)
Goriders
Howdy. As an update I went with a 3 ton 21” extension Torin Blackjack. Comes with a removable extension so it should also work on my daughter’s Forte as well.
Good deal on Amazon ($125) and checked out reviews on the google machine. I’ll be changing to winters in a couple of weeks. I’ll post my impressions if anyone is interested.
Dansflhti
Nova Scotia
Hello there.
I don't mean to change the subject here..but I'm going with winter wheels and tires too. Did you install tpms sensors in your winter wheels? It seems these new truck can support 2 sets on sensors.
Goriders
I’m keeping my winters on the OEM rims with the OEM tpms sensors.
I bought new TRD black rims and toyota tpms sensors for the summers.
I don’t know yet but I think the programming between the sensors can be done in the dash screens.
Dansflhti
Nova Scotia
I bought a set of used oem Off Road wheels for my Sport for winter. Also bought a set of oem sensors last week. I'll know in another 5-6 weeks how easy it is to set up the new sensors.
Goriders
if you remember let us know
Romer
Ken
Centennial, CO
Goriders
As an update. The floor jack worked great. Made tire change outs a breeze.
ArnoldN.
Arnold
Houston Tx
Figured I'll try here first. I'm running 34s on a 3-inch lift. I have a regular floor jack, and it was a pain to dismount my tires (I was going back and touching up my control arm, as it appeared from factory the paint wasn't done without contamination, surface bubbling, so I hit it with a wire wheel and recoated). Anyway, I was considering the badlands jack, but now I'm leaning more towards a bottle jack. I have a hi-lift that I can use with my sliders, but don't want to go that route. I'll be driving to Alaska from Houston and plan on doing some wheeling in MOAB. Any bottle jack recommendations that are both low(ish) profile and a good amount of extension?
Joshuwah
Oregun
2024 Taco TRD Pro Underground; 2012 BMW 335i F30 Sport Black
Bump on this thread........can you have two sets of wheels with two sets of sensors, and easily switch between the sets yourself and have the TPMS sensors recognized without complicated reprogramming? Sorry if there's another thread that covers this, but this one popped up first and I haven't looked further yet. thanks!
