EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter
BTAO
Andy
NE
2025 Trailhunter
Hey All! Ever wonder why nobody makes steps that just mount to standard 2" rock rails like the Trailhunter has? Me too. So, FTS, I'm making my own with OTS stuff from Amazon and Lowes. Now you can too, for a tiny fraction of the cost of anything else, and they are so low profile you barely notice them.
Here's the parts list:
Bar Clamps - 8x
Step Plate - 4x
Bedliner Paint - 1x
Abrasive Anti-Slip Tape - 1x
M8 FHSCS Stainless Steel Screws - 1pack
M8 Nylock Nuts Black Stainless Steel - 1pack
Anti-sieze or mild threadlocker
Tools:
Torpedo Level
M6 T-Handle and/or hex key
Adjustable Wrench
Tape Measure
Sandpaper/palm sander
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766107861759-00
There it is!
Here's the steps:
  1. Park your Taco on a level surface
  2. The plates are powder coated, so hit them with the palm sander to scuff them up a little and take off any sharp edges.
  3. Hang them on some fishing line or a thin metal rod somewhere you can paint them.
  4. Hit them with a few coats of bedliner spray paint.
  5. Determine your ideal step locations, measure and mark them so each side is the same
  6. Prep the clamps by taking out the rubber spacers and putting the thinnest ones for 2" rock rails in your pocket, and the screws and lock washers too
  7. Once the plates are dry, finger tighten the clamps to the plates to the side with the writing stamped into the plate (underside of step) using the flat head screws and locknuts
  8. Clean the bars using alcohol and a rag where they will go
  9. Place the spacers on the bar for each step, using one at your mark to locate it.
  10. Rough place the step and adjust the other spacer's spacing
  11. Place some anti-sieze on the threads of the cap screws with the lock washers
  12. Squeeze the clamps with the step roughly where it should be and use a T-handle with the screw to get it started. Repeat for the other screw
  13. Place the level on the plate
  14. Snug the flat head screws to the plate
  15. Get it level but note that it moves slightly as you tighten, so get it as tight as possible before your final adjustment
  16. Tighten the clamps, a little bit each side at a time so it doesn't twist
  17. Torque all the screws
  18. Repeat for all steps
  19. NOT SHOWN: I'm adding the traction tape, but it's not here yet. The bedliner if heavy enough could be enough forever, but I'm adding a second layer of protection for the hell of it. My plan is to be strategic and cut it so the edges can wrap around the front, angles and sides, hence the oversized tape. Heavy craft paper should work nice for a template. Plus, the grip tape will cover up the screws and holes. I want the tape to hit glue-glue at the holes to help capture it.
Finished, mostly:
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766109398097-kv
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766109447768-6
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766109462602-m3
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766109480319-k1
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766109491546-1x
2024 Tacoma EASY DIY Side Steps for ANY Tube Style Rock Rails - Executed on 2025 Tacoma Trailhunter 1766109574644-n
They don't even stick out past the fenders
What do you think? Suggestions? Thoughts? I'm not a huge guy, but they don't even hint at flexing. Solid.
I'd make the step plates out of 1/4" hard anodized aluminum if I were to sell them, but the steel ones here are galvanized, powder coated, bedlinered, and taped, so they should be okay for a while...
TH_Don
Alberta
2024 Trailhunter
I might make it longer (either two longer or one really long custom plate) to provide more rocker protection from rocks and spray.
androideld
Andy
Washington State
‘26 Taco TRD OR, w Tune M1
This looks really nice, really stout, and easy. The last item in your materials list is confusing and amusing: antiseize or threadlock. These are used for contradictory purposes…
TH_Don
Alberta
2024 Trailhunter
I also realize that your current design sits above the rails whereas my N-Fab steps sit well below the rail. Your design might survive off-road but some of my vertically challenged family might find the extra step in height challenging.
BTAO
BTAO
Andy
NE
2025 Trailhunter
Cool. I just wanted the single low-pro steps, but that makes sense.
I tried to use off-the-shelf parts to keep it super simple for anyone. There's longer tie plates available for sure, that you can just add supports as needed so it doesn't sag when you step. They even make stainless. Just go with the heavy duty ones, some are too thin.
BTAO
BTAO
Andy
NE
2025 Trailhunter
I hear that, it's not a low truck. But, it's just right that my kid and girl are able to easily get in when you don't have to pull yourself into the truck, or slide out of it. You just stand on the step and sit, or step down.
BTAO
BTAO
Andy
NE
2025 Trailhunter
Perhaps lol. The idea was to protect the anodized aluminum brackets that are threaded from galling over long term. Both do the trick. You don't really need the loctite with lock nuts, so the mild just seals the threads up nice. I used anti-sieze engine assembly lube.
BTAO
BTAO
Andy
NE
2025 Trailhunter
How have these held up?
Beautifully. Highly recommended still, wouldn't change a thing. I love how low pro they are. Solid and stable, and imo the perfect height to pivot up and into the seat. I tightened them down one more time during the winter when everything shrank for good measure, but rock solid. I have a gravel driveway, and fly fish all the time, so they get some wear. But it's bedliner, so i've just scuffed the surface on the driver side, and if it ever wears out, I can just pop them off and give it another coat to be good as new.
