Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
Upgrade your Toyota Tacoma with our SS6 LED Fog Light Kit, delivering powerful, road-legal performance and a clean, factory-style appearance. This bolt-on kit mounts a pair of 6-inch Stage Series LED Light Bars using CAD-designed brackets and factory mounting points. No cutting or drilling required! With higher light output, modern optics, and greater intensity than anything else on the market, the new Stage Series Lightbars are the most capable lightbars available today!
Designed for Performance. Each Stage Series Light Bar has been engineered from the ground up with the most modern optical, thermal, and circuit board technologies to provide more output than any other light bar on the market. Unlike reflectors, TIR optics capture and focus nearly all of the light output, shining it only where you need it, without glare or wasted light.
Thanks to copper circuit boards, thermal transfer materials, and optimized heatsinks, these lightbars effectively dissipate heat from the LED chips, allowing them to run at maximum power, producing serious light output.
Functional Beam Patterns. Each beam pattern has been fine-tuned for real-world conditions to perform even better than before.
SAE Fog uses our distinctive FineLine optic, which provides an exceptionally wide pattern. The SAE Fog optic shines with a 90x10 degree pattern to fully illuminate the area directly in front of your vehicle. They are legal for on-road use as fog lights (Please check your local laws and regulations for aiming, installation, and applicability).
Choose Your Power Level. The SS6 LED Light Bar is available in three different power levels. All options use high-intensity, automotive-grade LED emitters and TIR optics for unmatched focus and output. The Sport model offers the best bang for your buck, while the Pro model takes things a step further with a noticeable boost in power. The Max model is designed with cutting-edge automotive emitters for both high power and extreme intensity, using the same Osram HX Boost LEDs found in our Max power level SS3 and C2 2.0 LED Pods.
Amber Backlight. The SS6 LED Light Bars included in this kit come with an integrated amber backlight that fully illuminates the TIR optic, providing distinctive accent lighting and enhanced visibility when parked or stopped on the trail.
White or Yellow. This Stealth LED Light Bar Kit is available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
In the Box:
  • Four (4) Application-specific brackets
  • Two (2) 6" Classic or SS6 LED light bars
  • Two (2) H11 DT Adapters
  • Installation Guide
Warranty: Lifetime warranty
Return Policy: 30-day Return with no restocking fee
100% Satisfaction Guarantee
Fitment
NOTE: This kit is not compatible with the Trail Hunter trim or models equipped with Rigid Dual Color Fog Lights. This kit is for trucks equipped with fog lights from the factory.
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly manufacture and engineer our own products in the United States using globally sourced materials, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Gear_yyc
Any on-road demos of the yellow fogs compared to stock?
Also, for the backlight, are those always on like daytime running lights?
Mightyquinn
Andy
Fayetteville,NC
2025 TRD Pro Ice Cap/Cockpit Red
Do these plug directly into the factory wiring and maintain the function of the factory fog light switch? How do they compare the the OE Rigid lights?
Includes the H11 DT connectors, so yes - direct plug in with OEM lights.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
The yellow SS6 Fog Lamps are comparable in overall output and color to our yellow SS3 Fog Lights, but there are some key differences in design and performance.
The SS3 uses a square housing with four optics, while the SS6 features a rectangular housing with four optics as well. The SS6 is a newer design with more refined optics, resulting in a sharper cutoff and a more controlled beam pattern. While we don’t have dedicated on-road SS6 yellow fog demos available just yet, we do have on-road video examples of our SS3 yellow fog lights that accurately represent the color and general performance, which I can share below. We’re actively working on additional SS6-specific content for reference.
As for the backlight, it is not always on by default. The backlight can be wired to any 12V fused source of your choice, such as a side marker circuit, auxiliary switch, or other trigger depending on your setup. When the main beam is activated, it automatically overrides the backlight.
Canufixit
Canu
New England
2025 sr DC 4x
In the Box:
Questions/Concerns:
Hours:
Phone: 314-205-3033
For those of us with the SR versions - beware these may not fit without extensive bumper trim removal/cutting JMO
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
The SR does not come equipped from the factory with fog lamps. That would be an add-on kit that we do not advertise or offer at this time.
tkrum015
Ted
Olympia
Are the two videos of the yellow lights just the small fog lights?
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
The two videos from Instagram are just of our comparable SS3 fog lights on without low beams to showcase the width, intensity, and output.
tkrum015
Ted
Olympia
Thanks they do look pretty bright
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
They absolutely are! The all-new SS6 is our highest-performance road-legal option, offering an extremely wide pattern with impressive intensity. They’re also designed, engineered, and assembled here in the U.S. and backed by a limited lifetime warranty.
Here is an example of our SS6 Pro White kit on the 4th-generation Tacoma:
izzy
Bay Area
I'm ok with cutting the bumper up (such a dumb move on Toyotas part to not use a plug like all other factory fog deleted vehicles), if there's a kit with instructions/harness etc.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
There is no add-on kit from our team as a heads-up.
The alternative option would be a solution like the Baja 686 Industries add-on SS3 kit under the headlights.
Learn more here: https://baja686industries.com/pages/2024-toyota-tacoma
