Flaw in Toyota's Double Wall Hitch Receiver Design
gofastdan
I'm assuming that Toyota designed the new double-wall hitch receiver with structural integrity in mind, and maybe the design is what gives the hitch it's class 4 rating.
That's all well and good if you're towing something but what if you want to use the receiver to mount a shelf, swing out, bike rack, etc...? Again, all good until it comes to installing a pinch style anti-rattle clip of some sort like this.
Many rack manufacturers have a pinch style insert anti-rattle clip that is included with the rack. My Alta bike rack has a fancy version of this built into the insert and my RakAttach swing-out uses one as well. These things work great in most receivers and completely eliminate any movement but in order to completely take out the movement you really have to crank down on them. Some manufacturers, like Kuat, use a wedge style insert with a long screw inserts down the receiver tube but that's pretty rare.
Here's the problem. The double-wall receiver actually has two walls (duh!), the inner receiver and an outer shell. There's a ~1/4 inch air gap between the two and the outer shell is fairly thin....you see where this is going....when you torque down on the bolt the outer wall deforms. If you continued you might eventually pinch the outer wall all the way down against the inner receiver tube, but it seems likely to me that somewhere in that process you'll break a weld or some other bad thing.
I have a friend with a '24 Tacoma and he's used a Recon bike rack for a while now. He never noticed it but when we looked at his truck the outer wall was significantly deformed. Every time he puts the rack on it bends just a little more. It also seems to me that when you're driving on rough roads the constant twisting and pulling will probably deform it more and lead to it being loose over time.
I puzzled over how to fix this. There are external devices like this and for most people that's probably the best solution. They work pretty well and prevent most movement. I don't think they're as good as the internal pinch clips though, and my Alta rack actually uses both together to prevent the rack from moving.
In the end, here's what I did. I took my die grinder and reamed out the outer wall until I had enough room to fit a 5/8" steel bushing in. Now the bolt is pressing against the inner receiver and not the outer wall. Not many people will want to take a die grinder to their receiver but I'm not most people....
The reality is Toyota screwed this one up. If they really felt like we needed the double walled receiver they should have put an insert in so any force on the outer wall would be transferred to the inner receiver. Since they didn't you get to design your own solution!
Here's a video I sent to 1UP (maker of the Rakattach) showing them the problem. It's not their fault but I can see someone coming back and suing them for breaking their truck. Some of the video are my other comments on the swing-out (I love it) so you don't really need to watch the whole thing if you don't want.
RakAttach Video
Gratuitous pics of my set up. I have some cleanup to do but it's 90% there!
2024 Tacoma Flaw in Toyota's Double Wall Hitch Receiver Design PXL_20260303_012724826
2024 Tacoma Flaw in Toyota's Double Wall Hitch Receiver Design PXL_20260303_012713679
2024 Tacoma Flaw in Toyota's Double Wall Hitch Receiver Design PXL_20260303_014214261
2024 Tacoma Flaw in Toyota's Double Wall Hitch Receiver Design PXL_20260303_014239777
2024 Tacoma Flaw in Toyota's Double Wall Hitch Receiver Design PXL_20260303_012534542
trailhunger
2024 TH
Was about to pull the trigger on rackattach & the fold table & extension myself (nice setup) happened to come across this...Gonna take a look at my hitch tomorrow. Thanks for the heads up. How do you like the 1Up system? Decided if I get a swing out I'd get this one vs a Rigd
gofastdan
gofastdan
If you watch the video, I comment on a couple of very minor nit-picks on the RakAttach but they are minor and wouldn't stop me from buying it at all. It's a high quality piece! I also looked hard at Rig'd but for what I wanted I just couldn't justify the extra money.
My only thing I'm not liking so far (which I didn't mention in the video) is how stiff it is to swing open and shut. No ball bearings here! It's a blessing and a curse. You won't have to worry about the wind blowing it around if you forget to put the pin in. Heck, you won't need the pin at all. It's a workout to swing though. I could loosen the bolts a bit, but that would allow more play in it, which I don't want. I do hope it gets easier to swing over time though.
That said, I did not buy 1UP's table, I made my own. It just seemed easy enough, and it was. I bought these folding shelf brackets and used something like this piece of sandwiched aluminum (cut it to fit the size I wanted) for the shelf. I add a small aluminum U channel across the bottom of the shelf to add structural integrity to it. Easy afternoon project and half the price of the 1UP shelf. Somewhere out there is a review of the RakAttach and all the different accessories and the only thing that came across as not well designed was their table. The way the legs come up and attach to the table is really fiddly. Try and find a video of someone opening or closing it and I think you'll see what I mean.
gofastdan
gofastdan
Here's a good video. He opens the table in the first minute (that's all I watched of the video). I guess it's not that bad, but my solution is better! :wink: :ROFLMAO:
Edit: I went ahead and watched his whole video and he confirms my concerns with the table being a PITA, although a nice looking and functional PITA... Also, I notice the APS panel has been slightly redesigned since his video. The panel he has is locked into one mounting position but now you can mount the main panel in a couple of locations. I have mine mounted all the way out and have absolutely none of the clearance issues he talks about!
trailhunger
2024 TH
ugh, now that I look at it, the table leans wonky when arm is fully out & tailgate down. Bunch of loose bits & bobs, nothing tethered.. IDK...
I'm glad I just put a pod light into my hitch. I sold my kitchen gear slide that I built up, I guess I'll run a cheap free standing camp table or a DIY cantilever ledge somehow and save ~100 lbs & $1K, load the wife's bike on the GFC roof when I need to carry 2 on a long trip...6' bed is clutch for the bike, no dealing with rear sensors & cameras when it fits in the bed 🤙🏽
2024 Tacoma Flaw in Toyota's Double Wall Hitch Receiver Design 1772560723530-gr
