TRD Pro interior dash trim part numbers
tipsyjam
Hawai'i
Alright I wanted to ask:
I just realized that the TRD PRO Dash vents and AC control trim is a flat black
any possible way to get the part numbers for these?
Is the AC control trim by the radio screen a separate piece or would have to buy
Joseph, did you ever find the part numbers for the driver and passenger side black AC vents trims? Also, if you did, did you have to buy the whole vent assembly for each or were you able to find just the black colored trim cover part? Edit: Or did you just give up on it lol
I have AJT stick on covers on mine right now and they look good, but I notice they mess with the flow coming out of my vents so I was thinking to just replace them.
I was researching and found that 55650-AK010 looks to be the AC vent (whole assembly, though) for the driver side as the description specifically says with TRD Pro package. Passenger side I am having trouble confirming.
Center trim piece under screen around the climate control buttons is 55475-AK020 confirmed by someone on Facebook who installed it.
Please let me know when you get a chance.
2024 Tacoma TRD Pro interior dash trim part numbers 1000063629
JayTech
Jay
2025 Toyota Tacoma TRD ORP
Your 2 part numbers are correct for the driver and middle pieces. The passenger side piece is 55670-AK010 and yes unfortunately the trim does only come with the whole register for both the driver and passenger sides. They aren't too expensive though. I think you can get them online for about $130 each.
tipsyjam
Hawai'i
Jaytech thank you for the information and for confirming all the part numbers. I figured I would have to purchase the whole assembly for each but was hoping to get lucky with individual trim piece part numbers! The prices are not too bad though, like you said.
Nice headlights on your truck btw
tipsyjam
Hawai'i
I am 2 out of 3 for parts today. Thank you @JayTech for confirming part numbers for the AC vent assemblies with black trim. I had stick on covers on my original vents that blacked them out, but I noticed the airflow was a bit different afterwards so I decided to just get the actual vent assemblies and install them instead.
Install was easy on the driver side. You just need a trim prying tool and need to pop out the small carbon fiber looking trim piece above the aux buttons and below the vent. I popped off the side trim where the secret compartment is too. I then popped the vent out from the top down with the tool inserted behind the colored trim. New assembly snaps right back into place. I popped it in from the top to bottom as it was easiest that way.
Same thing on the passenger side, pop the trim off around the vent, but you will also need to pop off and bend the middle trim piece that says "TOYOTA" pretty far down towards the glove box to get the original assembly out. Don't worry, just bend it slowly and work the original vent out as best you can. It will come eventually. Carefully work the new one in the same way. I popped this one in from bottom to top.
2024 Tacoma TRD Pro interior dash trim part numbers 1000065080
2024 Tacoma TRD Pro interior dash trim part numbers 1000065081
2024 Tacoma TRD Pro interior dash trim part numbers 1000065082
2024 Tacoma TRD Pro interior dash trim part numbers 1000065085
Interestingly, I also ordered the armrest cover for the center console because I wanted the leather and also to test out which color is which of the various parts. I ordered part 58905-AK020-C2 because a few websites said it is "red" but what i got was a dark gray cover with bronze stiching. Quite nice, but i was actually looking for black leather with red stitching. I'm willing to bet it's the -C0 option that I am looking for but have not confirmed and probably won't in the future.
2024 Tacoma TRD Pro interior dash trim part numbers 1000065086
Anyway, I went to try install it on my TRD Sport gas model non premium, and turns out it doesnt fit. The original cover is the same material as the dashboard, that textured black plastic leather-like material that scratches incredibly easy. It's easy to remove, just open up the center console cover, remove the six Phillips head screws holding the cap to the hinge and button plastic piece, and pop it off.
I learned that the covers have these lips that are meant to receive clips that are on the plastic piece with the hinge and button you press to open the center console. On the leather one (I assume since it is from a premium trim), the lips are in different spots, maybe like 0.25 to 0.5 inches offset from the normal dashboard textured cap. I didnt find this out until about a half hour messing with it. Yet another part that can't be easily swapped onto lower trims!
Anyways, just FYI that you probably also need to buy the button and hinge plastic assembly piece from a trim that has the leather interior for the leather cap to fit if you want to go that route. To get that whole armrest lid assembly out, it looks like you gotta take off the center console.
I thought it would be made nicer, too, but toyota literally just stapled the leather to the plastic cover piece. Looks pretty whack but I guess you can't see it if it is installed. I will probably just cover my original armrest cover when I get katzskins since I want to do that eventually. Also to note that the leather is pleather. Says so on the back of the cover that the "skin" is just PVC.
2024 Tacoma TRD Pro interior dash trim part numbers 1000065088
Thanks for reading if you made it this far. TIL.
ElusiveAura
Marc
Tennessee
Toyota Tacoma Offroad Hybrid
2 questions. Will I have any issues ordering the entire door panels from toyota online? I wouldn't think so, right?
And 2, I know you work for toyota but when i google these part numbers i end up coming up with a trd pro red and a trd pro sensul (how its spelled) red. I am specifically looking for the black leather top pad with red stitching the inner panel leather piece to be completely red. That's these 2 part numbers? Is there a difference in the sensul red and trd pro red? Maybe google is on crack? I just want to verify before I put in the order. I have included a pic of the door I am specifically looking for. It comes with everything I need I assume, just a direct swap? If anyone else can answer this too, feel free. Thanks!
Driver side: 67620-AK061-C5
Passenger side: 67610-AK060-C5
2024 Tacoma TRD Pro interior dash trim part numbers images
