xipoqix_official
Jackie
China
We recently went through the process of adding bed scene lights to a base-model Tacoma that didn’t come with factory ones. I wanted to share a quick breakdown of how the install went.
I’ve put together a few photos and basic steps below in case anyone is working on a similar project. Hope this helps!
First, pop off the bed rail cap. Use a rotary tool (like a Dremel) with a cutting wheel, and carefully cut out the openings along the factory-molded guide lines.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (11)
Next, insert the scene lights into the cutouts you just made, and secure them using the factory mounting holes on the back.
Moving on to the wiring. Remove the factory side light and unplug it. Then, use the splitter harness to connect the factory plug, the side light, and the new scene lights.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (1)
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (7)
To keep things looking clean, route the wire under the bed rail cap and secure it in the clips.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (8)
Finally, snap the bed rail cap back into place to complete the installation.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (9)
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (10)
ejosesa
Joses
los angeles
tacoma off road 4x4
Interesting. I just replaced the caps entirely with the lighted version.
How much did it cost for just the lights and wire harnesses?
xipoqix_official
xipoqix_official
Jackie
China
It should also be worth noting that this title and thread only applies to the mentioned 3rd party lights (or any lights that cut out the caps).
Adding OE Bed Scene lights is a different process.
TX-MD
marvin
AR
Tacoma, 4Runner
Anyone have these already? I’m curious about any water intrusion under the rail cap and onto the underlying body panel - any more than the stock un-cut bed rail
Cabby30
CA
2024 DCLB TRD OR
Based on this image it doesn't look like there is any sealing involved, from the factory or this installation. I ordered these so I'll know more once I attempt the install when they arrive.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 1787186866940-lh
dante116
Don
Sacramento, CA
Looking forward to seeing how they turn out. I'm hoping you'll be able to do a little better job on the trimming than the install video shows.
Gaming
Gaming
2025 Tacoma SR5
If you make them available in Canada and make a smoked lens version, I would happily buy them and make an install/review video.
