GRKTRD
Nick
PHX
24 Tacoma
Not the same as the raptor as those are 35 (315s) these are essentially 34s. But same tires I ran on my last truck. Wonder if it rubs because this is exactly what I want to get into
Mykale220
Georgia
2020 Off-road (cement)
I’m still waiting on my OR premium to get off QC hold, but I’m planning on putting 35 12.50’s on it as soon as I get it. I just need to find a 3” lift to make it look right. The only lift that I could find out right now is the preload collars from westcott designs. Not ideal, but it’ll work temporarily.
Visa_Declined
OKC
TRD Off Road
285/75 will probably fit without rubbing, because I'm running 285/70's and there's at least 2" of clearance in the tightest spots. Without a lift though, I think 285/75's are a bit too large looking for the wheel wells.
2024 Tacoma 285/75/17 BFGoodrich TA KO All Terrain Tires on 2024 Tacoma TRD Off-Road IMG_0933
GRKTRD
Nick
PHX
24 Tacoma
I agree. Wonder how positive methods would do. That’s my only worry on that with a 34 on stock height. Been kinda waiting for this moment. Second is the weight. Would just run a C ply 33 instead of an e ply 34. Really wasn’t to bad on the 3rd gen. Truck was tuned on 91 though / intake and exhaust. So helped compensate lost power
Visa_Declined
OKC
TRD Off Road
I have not seen a single photo of a '24 Tacoma with aftermarket wheels where nearly half of the tire wasn't poking out of the fenders. It will likely take a positive wheel offset to avoid that, but until someone figures out the numbers, I'll run the stock wheels.
M1KL83
Tacoma TRD OR 6MT
My understanding is factory wheel is 6-139.7 60ET 95.1CB M14x1.50 studs or same as 3rd Gen Tundra specs. 3rd gen Tacoma Sport had 6.139.7 30ET 106.1 CB and M12x1.50 studs.
I could be mistaken I've been scouring the boards trying to get 100% confirmation since launch..
Finding positive offset anywhere near the factory 60mm is tricky especially in 95.1 hub. I've saved several wheels that are 20m to 35mm offset but even those will have 1 - 1.5" of poke compared to factory.
Seems Toyota has chosen a unique mix of wheel specs for the newer generation trucks.
GL Rockwell
George
Floreeda
20 tacoma OR
I prefer the added sidewall with the 17s.
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
What do you mean?
The KO was released in the 70s, the KO2 about a decade ago, and the KO3 is slowly being released now.
The KO3 has about a decade's worth of improvements over the KO2, primarily in dealing with water and snow. As expected: it's still pretty bad in mud.
Drtdzrt78
Placerville CA
2024 Tacoma Trd offroad
Is this stock height with no spacer?
myl
mike
new england
2025 Tacoma trd off-road
Are you sure these are 285/75/17? I have yet to see that size in the black lettering. I have only seen the white lettering for that size
