Instrument Cluster Set Up (Changes On Its Own)
PNWblue
WA State
Maybe they subcontracted the software out to GM :D
BMM123
Bruce
Tacoma Sport Premium
There was also a feature in the app he first couple weeks that showed you how you were driving and I can’t seem to find that anywhere now. It showed you exactly what location you hit the gas or brakes too hard. Would have been handy when you take your car in for service as I know lots of Corvette owners have seen their cars abused when they took them in for services.
It changed location whe the app was updated. Look under find and then driver pulse.
2024 Tacoma Instrument Cluster Set Up (Changes On Its Own) Screenshot_20240305_203925_Toyota
CATOY
NorCal
Can you set it up so it only shows the speedometer and fuel? That's all I really want to see most of the time.
The fuel always shows. You can try setting it up where you have the single dial in middle. It also gives you an option to select nothing for the left and right. I think you would better off with the single dial. You need to go through the settings, that one is a bit deep.
CATOY
NorCal
Mine actually stayed set for a few hours in my new configuration for screen 1, will see if it will hold overnight. All I did was swap left and right. Will check again in the morning.
2024 Tacoma Instrument Cluster Set Up (Changes On Its Own) IMG_5685
dvolman93
dvolman93
CA
2024 Toyota Tacoma
  • Mine actually stayed set for a few hours in my new configuration for screen 1, will see if it will hold overnight. All I did was swap left and right. Will check again in the morning.
    I tried doing that too and it didn’t stay.
dvolman93
dvolman93
CA
2024 Toyota Tacoma
Honestly, I’ve just gotten used to it. I put the navigation as one and if I needed to check the tires I just gotta go to edit it and scroll down. It is what it is until they fix it with an update.
CATOY
NorCal
  • I tried doing that too and it didn’t stay.
It's funny that it's the only one for me that doesn't keep the settings and it has only been the left side when I select tire pressures. Not a big deal and I'm sure it will get resolved in the future.
Planoman
DFW, Texas
If you updated your toyota app, you can go to find which is the bottom right button which shows where you are parked on a map, and from there select drive pulse & trips. You turn that on and it will track your driving. It give you a driving score.
CATOY
NorCal
My screen one display actually stayed as set, will monitor for a couple days and then switch it back to see if that’s some weird hole in their code.
2024 Tacoma Instrument Cluster Set Up (Changes On Its Own) IMG_5697
TalkingTaco444
Earth
What the hell is that all about? Wonder if it’s a bug and needs a software update.
If you are able to reproduce the issue doing the same actions as you stated in your original post, then yeah its a bug. I wonder if Toyota has a way to submit bugs from customers.
CATOY
NorCal
Well, it switched again. Funny that only the left side of screen 1 swaps. I’m sure they know it will hear about it. Just set both sides to boost to see how long that lasts.
rideradk
Glenville NY
2024 TRD Offroad
If the same software developers coded the safety sense features, makes you wonder what bugs might be in there ;) Dumb question- presuming there are bugs in the dash display or the infotainment system, how are software updates provided? Is that something that you have to go to the dealer for? Is it something you just have to live with?
