What are Type A and Type B tires?
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
I have a TRD Sport 6MT and I am reading through the owner's bible and was wondering what wheel size do I have, the 18x7.5 or the 18x8?
Looking to get a spare wheel...
2024 Tacoma What are Type A and Type B tires? thumbnail_20240416_145301
taco4moro
Los Angeles
2024 Tacoma TRD ORP
Might be relating 18” on the TRD Sport vs. the 18” on the Limited? Not sure which is which.
Reactions: oxi
oxi
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
Local dealer stated using VIN number that they are 18x7.5 Type A....
Where to find that size with bolt pattern?
BLtheP
TX
The 3rd gen Tundra uses an 18x7 spare which would work perfectly to replace your 17x7 spare. Width doesn't matter too much, the 1/2" won't make a difference and at least with it being an 18" you could put another full size 265/70R18 on it.
The Tundra shares the same smaller hub bore and same 6x5.5" M14 stud bolt pattern as the new Tacoma, so it should work perfectly.
Permanent Spare 2022-2023 TOYOTA Tundra Sequoia 18” OEM Steel Wheel Rim NICE! | eBay
oxi
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
What is the offset of the TRD Sport 18 x 7.5? 0?
Looking at prices of 18 x 7.5 out there is ridiculous. Does offset matter regarding a spare?
BLtheP
TX
The offset on Tacoma 18x7.5 is +55mm. I don't know what the Tundra spare is but I imagine it's close to that. The Tundra normal wheels I am seeing as +60mm on the forum and ebay listings. Spare is probably +55 or +60. Definitely nothing in either generation is anywhere close to 0mm offset, that would stick way out.
BLtheP
TX
Weird, most of the places selling that spare wheel are calling it 18x7.5. Still haven't found the offset yet. But I think an additional 5mm would probably fit fine, but you'd need to see how close you are to the control arm and such to confirm that.
