Limited trim OEM wheel specs
Ron
Samsara
Can someone confirm the factory wheel specs for the Limited ?
18 x 8 with 60 offset maybe ?
Would the hybrid be the same ?
The rest is the same as other trims.
6 - 139.7
Hub 95.1
M14x1.50 studs
@Discount Tire
ridetime
Oklahoma
The factory 18 inch wheel is 7.5 wide with a 55mm offset. The bolt pattern, hub and stud size is correct.
On behalf of the forum your tire wheel knowledge and contribution is much appreciated. Sooner or later everyone needs tires and I have a new DT right down the street!
Discount Tire
Arizona, USA
All Things Toyota
Thank you for your kind words. We would love the opportunity to get you taken care of. Please let us know if there is anything we can do from here to help facilitate your tire purchase journey.
What about the option 18" TRD rims?
Tsturbo
Terry
WA State
‘24 Tacoma Limited
The TRD wheels would be 18X8 with a 45mm offset.
Thank you! Do you know the weight of these?
Also between the stock vs the TRD wheels and the slight wheel width and offset, would the TRD wheels have slightly wider stance? And would the stock Limited rim have a slightly higher stance being only 7.5” vs 8.0”?
Goriders
2024 Tacoma Sport Plus
Wider stance yes. 8” is the width. Wouldn’t effect height.
Discount Tire
Arizona, USA
All Things Toyota
These wheels show to be 28lbs. The offset and width will give you a greater stance.
2024 Tacoma Limited trim OEM wheel specs 1715265458052
Ron
Ron
Samsara
Will 265/70r18 fit on stock rims - no lift , no trimming ?
Discount Tire
Arizona, USA
All Things Toyota
Toyota has made the gen 4 Tacoma capable of 33 inch tires. The 265/70R18 is 32.6. It would be a solid fit.
Reactions: Ron
Ron
Ron
Samsara
Thanks - I’ll stop by the store when I get the truck
Lets_Taco_Bout_It
Seattle
2024 Bronze Oxide Trailhunter
@Discount Tire
Just purchased a set of BFGoodrich All Terrain T/A KO3 LT285 /70 R18 127S E1 RWL, Will these fit the Trailhunter Hybrid trim levels? Will i have to adjust any of the offsets? I will be putting these on the stock 18" rims. Getting them installed next week on the 29th at the 1st Avenue S location in Seattle, WA. Anything I need to let the folks know at the store before they do their work?
ToEkUttEr
Dee
So did they fit after all? :)
