Tom Sellick
Ontario
2024 TRD Pro
Thanks so much for the reply :). After reading your post I crawled underneath. I need to clean off some dirt to confirm what setting is established. Before I turned the switch I thought I should take a gander at instructions or a manual, but I can’t seem to find. Straightforward enough right?
Did you figure this out by chance? Is 1 the road setting?
@Tom Sellick I saw a video where Sheldon Brown said that setting 1 is the default road setting. I read that Pros were being delivered set at 2 however. It is strange that there is nothing in the manual about that though.
Tom Sellick
Ontario
2024 TRD Pro
I think you are right! I saw that video. Now I just need to figure out which end of the dial should be pointing to 1. ??. I think I have it. Just trying to find confirmation.
Yeah - that is not very clear and it should be marked better. In your picture my guess is that it is set to 3.
Tom Sellick
Ontario
2024 TRD Pro
Ok. That’s what I think too. I turned them in the other direction to 1. So hopefully I’m good.
jayrad44
Jason
Official description of the TRD Pro FOX suspension:
TRD Pro comes fitted with TRD-tuned FOX® QS3 three-way adjustable internal bypass shocks with remote reservoirs for improved high speed off-road performance and external FOX Internal Floating Piston (IFP) rear bump stops to improve bottom out feel.
TRD Pro features TRD-tuned FOX® QS3 internal bypass shocks with 2.5-inch aluminum housings and rear remote reservoirs. Quick Switch 3 (QS3) technology allows for manual adjustment of compression damping on each shock to match the terrain.
Will these shocks fit on a 2024 Tacoma off road. I want to lift it maybe using Toyota parts?
