Anyone Install Seat Covers?
2024 TRD Sport-Bronze oxide.
I'd like to know if anyone has gone the cheap route, ie. Walmart, AutoZone, etc. If so, what brand and model number did you get.
robfultz
Rob
2024 Tacoma Off Road
Would you be willing to take pictures? Specifically of the smaller of the two back seats where the back portion tucks under around the seatbelt?
I received my rears yesterday and installed them. The split seat turned out perfect other than one hole being cut a little out of place. But the non-split side seems like the fabric was cut wrong for me. Had my brother take a look and he wasn’t able to get it any better. As the other side turned out perfect I’m inclined to think it isn’t user error.
trying to decide if it’s worth keeping overall despite the one area of poor fit or if I should just suck it up, accept the defect and avoid re-installing or trying another brand. If they were $150 for the full set it would be a no brainer, but for $300 I want it to fit right.
Fronts arrive Saturday for me. Hope the fronts fit like the double seat in the rear.
Here yea go. Mine were OK.
2024 Tacoma Anyone Install Seat Covers? seat20
2024 Tacoma Anyone Install Seat Covers? seat21
2024 Tacoma Anyone Install Seat Covers? seat23
2024 Tacoma Anyone Install Seat Covers? seat22
TheBandit
Stephen
Denver
2024 Toyota Tacoma SR 6MT 4x4
Did you do anything different or special to get it to look as good as yours does
If I’m understanding the question right, I noticed they looked a bit silly when I put them on first as well. When I lifted up the bottom of the seat after install, I pulled the material through from the bottom side, and that helped a lot instead of trying to push from the top. Let me know if you have any other questions.
Also:
When you go to put the front seats on be mindful of the bottom cushion cover and look at how the side plastic tube is shorter on one side (they are not symmetrical) and look at the orientation I have in my pics
2024 Tacoma Anyone Install Seat Covers? IMG_4372
Edit: I also believe my split seat side may have just been made more exact. If you have already tried removing and refitting them, you might contact EKR, I had pretty good luck reaching out to customer service about shipping questions
TheBandit
Stephen
Denver
If I’m looking at your fronts right, you may have the two seat cushion covers switched. If it’s worth the effort, the orientation helps fit around the seat pivot and buckles much more comfortably
robfultz
Rob
hey thanks.
I just checked & both Air Bag tags are on the door side. I believe that’s correct..
Bandit, is that correct?
Rob
TheBandit
Stephen
Denver
hey thanks.
Rob
Yep, the uppers look right (airbag flap to door), but those bottoms are switched. I did the same thing when I put on the drivers side, and the pinch at the seatbelt annoyed me enough that I went through and swapped it just so I wouldn’t think about it forever haha
robfultz
Rob
Oh yea, you right!!!
looks like I got a project for tomorrow!!!
lol
Thanks again
Rob
bitflogger
WI
From noticing the SRS on seats I got these air bag compatible covers we're very happy with. They're definitely nicer than neoprene and bulkier stuff. Just popping the top over the head rests is sufficient for when I use them. Easy to remove also means easy to clean. For rear I have a simple Cabela's coated nylon cover bought long ago that's fine for as needed.
To each their own, but we're happy with retaining the air bag compatibility and the way the front and rear covers are also easy to clean or dry. I stow the all of it under the rear seat.
batman900
Oklahoma
24 Tacoma OR
Put my Rough Country covers on this morning, fit is amazing as always with these. The backs were easy but the fronts were time consuming trying to avoid pinching any wires underneath.
TheBandit
Stephen
Denver
Do either of you have pictures of your covers installed so I could get a sense of how they look? It may also help other people if they're deciding on what to buy
Could you attach a new link to these? The Amazon link isn't working on my end at least
bitflogger
WI
This is the share link from Amazon. One side short fleece and the other waterproof. I don't keep them on all the time and just if I'm full of dirt or sweat. They might not be for everyone but we like them.
DREAMANIA Waterproof Seat Cover...
batman900
Oklahoma
24 Tacoma OR
2024 Tacoma Anyone Install Seat Covers? IMG_2911
RiversideTaco
Gil
EASTVALE
2024 Tacoma TRD Off Road
Has anyone gotten new seat covers on the new Tacoma if so can you tell me what kind and how they feel and look
I installed the RC seat covers and the front seats fit ok. The side straps don’t have a place to secure them from. I don’t think they were meant for the electronic seats. The back seat fit perfectly. I thought about returning them, but it’s more of a hassle. So, I plan to keep them for a while and see what happens. My main concern is keeping the seats clean as I off road often.
2024 Tacoma Anyone Install Seat Covers? IMG_2157
2024 Tacoma Anyone Install Seat Covers? IMG_2158
