I want MPGs BY TANK to display, can’t figure it out?
Tsturbo
Terry
WA State
‘24 Tacoma Limited
2024 Limited Hybrid, currently running in “comfort” mode. I have gone through all the different set up’s and canned figure out how to get it to display MPG’s per tank. Any help appreciated!
SilverSurfer
Tacoma TRD OR Premium Plus
I can appreciate wanting that. It used to be so easy and now it’s buried behind digital menus. I was looking for a reset the other day and gave up. I’ll be waiting until my next fill up to start over. It’s not the end of the world, since it’s a truck, I don’t exactly have high expectations.
Tsturbo
Tsturbo
Terry
WA State
‘24 Tacoma Limited
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
Took me a little time to figure out how to do it.
After tank fill up ….
1. Vehicle info on your display
2. Trip information
3. History
4. Tap tap Update
Your previous Average MPG will move to the left and your new Average MPG will start to the right. This will also reset your Total Average setting in your instrument cluster. The pictures are a little misleading because the MPG numbers are different, but that because I was sitting in the truck in the driveway, with it running and the MPG was changing, both the places will show the same MPG. Do this at each fillup. If you tap Clear
All - All your data will be cleared and it will start over. I don’t see a need to ever do that.
Total Average is total since you tapped Update.
2024 Tacoma I want MPGs BY TANK to display, can’t figure it out? IMG_1501
2024 Tacoma I want MPGs BY TANK to display, can’t figure it out? IMG_1500
2024 Tacoma I want MPGs BY TANK to display, can’t figure it out? IMG_1502
Dansflhti
Nova Scotia
2. Trip information
3. History
4. Tap tap Update
My truck does not display the previous best. It always reads 0.00. I've commented on this before but still havent found the reason.
HoptownBob
Bobby
Hopkinsville, KY
Are you tapping Update “not clear data”?
That it the only thing that I can think of that would do that. It will only show previous best after you tap update and a new bar starts the right of the current one.
Dataman
Randall
2001 1st Gen Toyota Tacoma
I would just love to have displayed the traditional analog "meter" display of how much gas is in my tank. I have noticed that the current display of how many miles left in my tank changes seemingly dependent on current mpg average.
Why not just dedicate one of your two trip counters to the tank? And reset that one each fill up. That's how I've always done it and I suspect how they are assuming you'll do it.
How often do you really need two other trip counters at the same time?
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
There's a bar meter under the DTE number. On mine it has been fairly accurate (fill up at quarter-tank is ~13.5 gal). I just treat the DTE as entertainment.
Wouldn't mind if there were a way to hide it. Maybe a piece of black tape??
I do miss the dial gauge on my 2013. The graduations were 1 gallon and it was really accurate.
Dansflhti
Nova Scotia
Every fill up..I tap update.
2024 Tacoma I want MPGs BY TANK to display, can’t figure it out? 20240714_143516
HoptownBob
Bobby
Hopkinsville, KY
Yep, I see that you are. Not sure why you’re not getting the previous best. May a call to connect services and they should be able to get you to the right person to talk to. I fought a dealership would be able to help, apparently some of them don’t even know that a 14” screen is available ?
Just to see if we can figure this out:
Do you have the Total Average MPG as one of your instrument clusters display, like I do in my pictures? I’m just thinking if you don’t maybe that is keeping it from showing up.
Dansflhti
Nova Scotia
I don't have Total Average as one of my options. I'll enable that this weekend and see what happens.
