Limited trim OEM wheel specs
Ron
Ron
Vancouver Island
Ram 3500, Honda Pioneer 1000
Can someone confirm the factory wheel specs for the Limited ?
18 x 8 with 60 offset maybe ?
Would the hybrid be the same ?
The rest is the same as other trims.
6 - 139.7
Hub 95.1
M14x1.50 studs
@Discount Tire
ridetime
Oklahoma
2024 Tacoma Limited, 2023 Wrangler 392, 23 X5 M50i
The factory 18 inch wheel is 7.5 wide with a 55mm offset. The bolt pattern, hub and stud size is correct.
On behalf of the forum your tire wheel knowledge and contribution is much appreciated. Sooner or later everyone needs tires and I have a new DT right down the street!
WKTJR1
Maine
2013 Tundra CrewMax
What about the option 18" TRD rims?
Tsturbo
Terry
WA State
‘24 Tacoma Limited
The TRD wheels would be 18X8 with a 45mm offset.
Thank you! Do you know the weight of these?
Also between the stock vs the TRD wheels and the slight wheel width and offset, would the TRD wheels have slightly wider stance? And would the stock Limited rim have a slightly higher stance being only 7.5” vs 8.0”?
Goriders
2024 Tacoma Sport Plus
Wider stance yes. 8” is the width. Wouldn’t effect height.
Discount Tire
Arizona, USA
All Things Toyota
These wheels show to be 28lbs. The offset and width will give you a greater stance.
2024 Tacoma Limited trim OEM wheel specs 1715265458052
Ron
Ron
Vancouver Island
Will 265/70r18 fit on stock rims - no lift , no trimming ?
Ron
Ron
Vancouver Island
Thanks - I’ll stop by the store when I get the truck
