izzy
Bay Area
Had a weird vibration at 55mph, truck refused to accelerate, I finally put my foot in it and it kicked down to 5th.. after at least like 10 seconds of vibrating and zero forward acceleration. Weird...
ctngo82
Tha
Georgia
2025 Toyota Tacoma TRD - OFFROAD
Has anyone else had a vibration/rumbling in their truck that was confirmed to be something other than wheels and tires?
I need to get this fixed so I can go snowboarding soon!
My automatic 24 TRD OR developed a weird vibration at 9700mi and I'm going back to the dealership on Tuesday for the second time after opening a case with Corporate Toyota - the first tech test drove it with me and only said "it's a truck, it's not supposed to be smooth".
It feels like I'm driving over rumble strips, or a tire/wheel is extremely out of balance. But just in the rear half of the truck.
My truck doesn't fall under the transmission recall either.
Details:
Started suddenly at 9700mi.
Speed dependent, 20-40mph, worse on decel/coast. No change when I shift manually to different gears.
Not in the front end - felt through the seat and chassis only.
Not the engine - no change when I shift to neutral while coasting.
Not the front driveshaft/diff - no change in 4wd.
Not tires/wheels - no change when I swap back to stock, or rotate to different positions.
Not the tonneau cover or bed mat - removed them.
No change with 500lb loaded into the bed, squatting the rear end ~1.5".
My thoughts are that it's either the transmission, rear driveshaft, or rear diff.
Watch this video maybe this is the problem.
That is easy to diagnose. After installing a lift is when it starts to be a problem, if it goes away with 4X4 engaged it’s most likely the needle bearing. I replaced mine but from what is being described I doubt it’s the needle bearing.
