2 Wheel Drive Tacoma - how do it drive in snow and ice?
Roger Rabbit
Roger
Woodville, Alabama
2024 Toyota Tacoma
Do they go through snow and ice good? 2024 Toyota Tacoma 2 wheel drive!
Gear_yyc
Depends on your experience driving in snow and ice previously. They're capable in light snow and ice, with good tires and you might need some weight in the back.
bigd9247
Dalton
Washington
2024 TRD ORP, 2018 F150 XLT
Lots of sand bags in the bed for added weight will help with traction.
Roger Rabbit
Roger Rabbit
Roger
Woodville, Alabama
2024 Toyota Tacoma
Thank you, I have had older 4-wheel drive Toyota trucks that did great in snowy roads, but had a 2000 Tundra, great truck, but you were lucky to get out of your driveway!
Dirt
Greg
Eastern OR
I agree with Gear_yyc from my experience with Toyota 4x2's. Swing by your local tire store and pick up a good set of tire chains just for insurance. (I put about 200 lbs. in the bed)
Roger Rabbit
Roger Rabbit
Roger
Woodville, Alabama
2024 Toyota Tacoma
I agree with Gear_yyc from my experience with Toyota 2 X 4's. Swing by your local tire store and pick up a good set of tire chains just for insurance. (I put about 200 lbs. in the bed)
Thanks for reply, this is what I want to know, getting little older now, I always went around here where I live in bad weather to see who I get out of ditch, but not now!
Put a good set of all-weather tires on and a couple of hundred pounds of weight in the back, and she'll do well.
MJB4450
2025 SR5
I also have a 2WD. The first thing I'd do in your case is ditch the Firestoned tires if yours has those. Mine were spinning with light throttle on a dirt road. I was thinking about finding a set of 4WD takeoff wheels and tires that people put on Craigslist all the time when they buy a new truck and immediately get aftermarket. At least you'll have much better traction with those. Or simply swap out your tires for better one's. I still don't know if disabling the traction control will help or hurt. Apparently the limited slip works better with TC off in snow.
Roger Rabbit
Roger Rabbit
Roger
Woodville, Alabama
2024 Toyota Tacoma
Thanks for the info, makes me wonder if should get an ol Willis to keep around just incase!
MJB4450
2025 SR5
I've only had one AWD vehicle in 55 years of driving and had little trouble with 2WD (or 1WD in actuality). Which is why I opted for a 2WD this time since these come with limited slip diffs. But I am rarely in a situation where I might need a 4WD. These are very capable trucks if you have the right equipment on them. I've never been impressed with Firestones. If you're rarely in snow or sand, a good set of tires should get you by with a 2WD.
Roger Rabbit
Roger Rabbit
Roger
Woodville, Alabama
2024 Toyota Tacoma
Thanks, we have some snow and ice sometimes, but I don't have to go like when I was still working, I thank you for the info about this truck, I forswore check the tires!
