2025 Trailhunter factory wheel specs - offset?
humblehyper
CA
2025 Tacoma Trailhunter
Hi guys, what's the factory wheel specs including offset for this model? Thank you!
Skybot
Skybot
Hawaii
Tacoma Trailhunter
• Wheel Diameter: 18 inches
• Wheel Width: 8.5 inches
• Offset (ET): +20 mm
• Associated Factory Tires: 265/70R18 all-terrain (e.g., Goodyear Territory R/T, ~32.6 inches overall diameter)
Hope this is helpful.
humblehyper
CA
I'm trying to order custom wheels, will this setup work without fender modification?
2024 Tacoma 2025 Trailhunter factory wheel specs - offset? 1764444264586-2
Compherh
Sam
Miami
2025 tacoma limited hybrid
I have 18x9 with +20 offset, but using 275/70R18. Full turn, I can fit my finger between tire and fender. Just enough for flexing the suspension on the street, but I wouldn't want to go baja driving with that little spacing.
Compherh
Sam
Miami
Can someone please confirm if these are the correct specs? Thank you!
The only one I'm not sure is hub, I beleive it's 95.10. My after market wheels came with a centering ring from 106 wheel to hub 95.10. It went inside the Fuel Wheel, before mounting on vehicle. Most aftermarket wheels come with a larger diameter for the center (hub).
Also the oem lug nuts do not fit Fuel Wheels, they are round ball seat on the end. The wheel takes conical seat. Whomever you buy wheels from, should know this (aka tirerack or customoffsets).
