- First Name
- John
- Joined
- Jun 10, 2026
- Threads
- 2
- Messages
- 5
- Reaction score
- 3
- Location
- Washington
- Vehicle(s)
- 2026 Toyota Tachoma TRD Sport
Just bought a new 2026 Tachoma TRD Sport 4WD and wanted to get rid of the worthless felt guard and replace it with a good front and crank case skid plate set up. I received my skid plates from Rough Country specific to my make and model. Removed the front felt thingy, loosly mounted the crank case plate then attempted to mount the front skid plate. Everything was fine until I tried to put in the two front bolts and the existing cross bar prevented the bolts from reaching the threaded holes by almost 3/4 of an inch! I contacted RC and they asked for pics and after looking at them they said I would have to cut off the cross bar to make it fit! The instructions that came with the plates said “no modifications would be required to the existing vehicle”. I am very reluctant to cut off the cross member and am fairly certain it would void my warranty! The only work around I can think of is buying longer bolts to reach the threaded holes, but then I won’t be able to torque the bolts down without either bending the plate or risking the bolts working loose if simply snugged tight. Anyone who has had a similar problem and would like to offer up a good solution I’m all ears. Thank you in advance!
