Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
Cali Raised LED · caliraisedled.com · 888-385-5036 · [email protected]
Updated November 2026 with current links, specs and regular prices. Check the product page for any active sale.
Ditch Light Bracket Kit for 2024+ Toyota Tacoma (from $169.99): https://caliraisedled.com/products/ditch-light-bracket-kit-for-2024-tacoma
  • Brackets attach to the hood hinges using factory mounting points. No drilling, and the hood opens and closes normally.
  • Kit includes the brackets, LED ditch light pods (18W white, 18W amber or 27W side-projecting) and a wiring harness with relay, fuse and a standard switch. Optional Toyota OEM square-style "Ditch Light" switch.
  • Fits 3x2 and 2x2 pods. Aim about 45 degrees off the truck for side lighting.
  • Install about 1–2 hours with basic hand tools.
  • Brackets fabricated in-house in Fort Worth, Texas; LED pods are made overseas.
Install video:
All 2024+ Tacoma parts: https://caliraisedled.com/collections/toyota-tacoma-2024
Support: 2-year warranty (https://caliraisedled.com/pages/warranty) · install guides: https://caliraisedled.com/pages/installation-resources · questions? Reply here, call 888-385-5036 or email [email protected].
Photos
2024 Tacoma 2024+ Tacoma Ditch Light Bracket Kit – Bolt-On Hood Hinge Mounts 1708032908235
ToyTrucker
Jim
TX
Nice to see aftermarket lighting already. Any specs on angle and output of the light beam from the ditch lights?
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
Thanks we appreciate it! Here are the specs: the 27W side-projecting pods put out 2,500 lumens each and project light ahead and directly to the side. The 18W pods put out 1,800 lumens each with a flood beam (white or amber).
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
Our ditch light kits are available! They are in stock and ready to ship. Keep an eye out for more Tacoma and lighting content!
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
tkrum015
Ted
Olympia
Watched the install video. You did not share anything on how to get the switch panel out. Is it just a firm pull around the edges or is their something that needs to be removed under the dash?
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
Just a firm pull! Its held in there by 4 pressure tabs, just grab either side and pull it off!
tkrum015
Ted
Olympia
Do I need to remove the trim under the AC vent first? Thanks will take a closer look.
CuriousTaco
Seattle
TRD OR Base
It's easier to pull off if you pop that smaller trim piece off first. Gives a little bit better visibility of what's happening too. It's all clips, but there's also a single bolt at the bottom of the plastic piece that I removed so I didn't snap the plastic.
Was a little sketchy the first time, but then it got easier the second and third ?
tkrum015
Ted
Olympia
Thanks for your help. Did you add some of your own switches in the blanks. Looks like we have the same truck.
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
