Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
:fistbump: :fistbump:We’ve been heads-down getting a new batch of Tacoma accessories ready, and quite a few Mabett products are expected to go live around mid-July.
Here’s a first look at two of the upgrades we’ve been working on. Keep an eye on Mabett—we’ll be sharing more soon.
Hood Struts
The factory hood prop rod works, but it also sits in the middle of the engine bay when you’re checking fluids, cleaning, or working under the hood:facepalm::facepalm:
Our upcoming hood strut kit for the 2024–2026 Toyota Tacoma replaces that manual setup with gas-assisted support, helping raise and hold the hood while leaving the center of the engine bay open.
The kit uses the factory mounting points for a direct bolt-on installation with no drilling or permanent modification.
The brackets are made from carbon steel with a black powder-coated finish for added strength, scratch resistance, and corrosion protection.
Front Windshield Sunshade
We also have a new front windshield sunshade coming for the 2024–2026 Toyota Tacoma Double Cab.
It is designed for owners who regularly park outdoors and want a practical barrier against direct sunlight and heat buildup inside the cab.
Its three-layer construction combines reflective aluminum foil, a KT-board core, and soft felt backing, while the foldable design makes it easy to remove and store in the cab.
Which one would you like to see in more detail next—the hood struts or the sunshade?
Want to follow our upcoming Tacoma releases more closely👀
Join the Mabett 4th Gen Tacoma Garage for early product updates, member-only coupons and exclusive discounts. From time to time, we may also invite a limited number of selected members to test upcoming products.
Mabett
Mabett
LA
www.facebook.com
More new product updates coming your way this week — stay tuned!
chrissd
chris
San Diego, CA
2025 Tacoma Trailhunter LB
Could really use a bit more space around the mirror cutout for the dash cam.
Mabett
Mabett
LA
www.facebook.com
Of course, we took that into consideration during the design process.
redlimitediforcemax
Oregon
Is Mabett going to be making a rear floor air vent diverter so it can redirect the air to the body instead of the feet?
Thanks!
Mabett
Mabett
LA
www.facebook.com
Thanks!
Really appreciate the suggestion! We need to run a few product research within the community before moving forward. :like:
