TCDC
Can.
26 Trd,23 Ridgeline.
Has anyone discovered a work around for the 2026 Tacoma Hybrid. Shutting off a hot engine every time a person stops can’t be good for a hot engine with turbo charger.
Since it's a hybrid, I don't believe there's any way around that feature. I can't remember exactly if there's any trims that are 100% gas with the Auto Start/Stop, but you can get around those systems.
Hybrids are just stuck with that.
Rising Sun
Tom
North Georgia USA
2025 Toyota Tacoma Trailhunter
Press the tow/haul mode and it keeps the engine from cycling off until it’s turned offz
TCDC
Can.
Yup New stuff is still Junk 🤬🤷🏽‍♂️😂😂😂
Not sure but I think I’ll try the to haul method not sure on rh manual way though as this is automatic truck .
Chico
Arnaldo
2024 Toyota Tacoma
The start/stop system on a Toyota Tacoma Hybrid work different than in than the old start/stop non-hybrid systems, In the new Tacoma hybrid the electric motor takes over when the engine stops to provide power and get the car going again. I would not worry about wear and tear on starter, battery or engine , the engineers at Toyota did all that for you already when they designed the truck. I know that there are some companies out there selling start/stop eliminators, I'll stay away from those.
